Discuss
Whirlpool Dryer seems to work but doesn't dry
 in
Dryer Repair
I have a Whirlpool model #LGB6300PW0 gas dryer that has suddenly stopped drying properly. The ignitor works and the burner
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer seems to work but doesn't dry
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-14-2008, 09:13 PM
wjbertrand wjbertrand is offline
Junior Member
wjbertrand is on a distinguished road
Unhappy Whirlpool Dryer seems to work but doesn't dry
Model Number: LGB6300PW0   Brand: Whirlpool   Age: 1 - 5 years
  1. I have a Whirlpool model #LGB6300PW0 gas dryer that has suddenly stopped drying properly. The ignitor works and the burner lights, the drum tumbles and there appears to be plenty of air flow out of the exhaust vent. That exhaust flow doesn't feel very warm however. There just seems to be a lot less heat being generated than is needed to do the job, but it doesn't make sense since I can see the burner lighting up, apparently normally. Do I have a bad thermostat or is there some other explanation? Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-15-2008, 06:36 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Intermittant coils most likely
If these guys get a tad faultydryer coil kit.jpg they will work once and then quit, cool down after a few hours and work some more. They are around 20 bucks and easy to replace yourself. I would try that.
  #3 (permalink)
Old 05-15-2008, 09:15 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is remove the front and the rear panels. Remove the lint chute assembly (#1 on the break down diagram) and clean all parts from lint. Make sure the blower wheel is not broken.
Assemble it back and run a few loads with the vent hose disconnected from the dryer.
Post the results.
Here are the break down diagrams for the Whirlpool dryer Model LGB6300LW0
__________________
Professional appliance repair services in Orange County, California.
  #4 (permalink)
Old 05-17-2008, 07:53 AM
Junior Member
Default
Thanks guys. I've got the thing all apart. There's a little lint lining all the chutes and ducts but it's not obstructed anywhere. When I watch it run I can hear the soleniods turning on and shutting off the gas in a positive manner (clicks). Does that sound like weak coils? It seems like the burner shuts off before things really get going though.
Also, I removed the cycling thermostat (# 9 on the bulhead diagram) and it rattles as though there is a loose piece inside. Is it supposed to rattle like that?
What is the likleyhood that the Thermal Cut off sensor #17 or the T-Stat high limit, # 15, are bad?
  #5 (permalink)
Old 05-17-2008, 10:11 AM
Senior Expert
APP Volunteer
Default not likely
I do not think so. You can bypass them temporarily to see if the dryer starts working.
  #6 (permalink)
Old 05-20-2008, 09:00 PM
Junior Member
Default
Quote:
Originally Posted by SublimeMasterJW View Post
If these guys get a tad faultyAttachment 257 they will work once and then quit, cool down after a few hours and work some more. They are around 20 bucks and easy to replace yourself. I would try that.
OK, you called it Sublime! The guy at the appliance store was very confident that a set of new coils would fix my problem so I bought a set and sure enough, that was it! The dryer is now back in service.
Just wanted to close the loop on this one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool microwave displays F2 - doesn't work rsgators2001 Microwave Repair 2 06-02-2008 09:02 AM
whirlpool oven will not work charles e jimison Oven Repair (including Ranges and Cooktops) 1 01-24-2008 03:50 PM
Whirlpool won't cycle, diagnostics work drwhite Dishwasher Repair 0 12-16-2007 08:05 AM
whirlpool oven does not work bob zaveri Oven Repair (including Ranges and Cooktops) 1 08-30-2007 07:43 PM
Whirlpool AC won't work lemiley Heating, Ventilation, and Air Conditioning (HVAC) 4 08-01-2007 02:34 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
