| » Whirlpool Dryer seems to work but doesn't dry |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: LGB6300PW0 Brand: Whirlpool Age: 1 - 5 years
If these guys get a tad faultydryer coil kit.jpg they will work once and then quit, cool down after a few hours and work some more. They are around 20 bucks and easy to replace yourself. I would try that.
The first thing I would do is remove the front and the rear panels. Remove the lint chute assembly (#1 on the break down diagram) and clean all parts from lint. Make sure the blower wheel is not broken.
Assemble it back and run a few loads with the vent hose disconnected from the dryer. Post the results. Here are the break down diagrams for the Whirlpool dryer Model LGB6300LW0 Gene.
__________________
Professional appliance repair services in Orange County, California. |
Thanks guys. I've got the thing all apart. There's a little lint lining all the chutes and ducts but it's not obstructed anywhere. When I watch it run I can hear the soleniods turning on and shutting off the gas in a positive manner (clicks). Does that sound like weak coils? It seems like the burner shuts off before things really get going though.
Also, I removed the cycling thermostat (# 9 on the bulhead diagram) and it rattles as though there is a loose piece inside. Is it supposed to rattle like that? What is the likleyhood that the Thermal Cut off sensor #17 or the T-Stat high limit, # 15, are bad? |
Quote:
Just wanted to close the loop on this one. |
| Display Modes | |
| Whirlpool AC won't work | lemiley | Heating, Ventilation, and Air Conditioning (HVAC) | 6 | 08-11-2008 08:50 PM |
| Whirlpool microwave displays F2 - doesn't work | rsgators2001 | Microwave Repair | 2 | 06-02-2008 09:02 AM |
| whirlpool oven will not work | charles e jimison | Oven Repair (including Ranges and Cooktops) | 1 | 01-24-2008 03:50 PM |
| Whirlpool won't cycle, diagnostics work | drwhite | Dishwasher Repair | 0 | 12-16-2007 08:05 AM |
| whirlpool oven does not work | bob zaveri | Oven Repair (including Ranges and Cooktops) | 1 | 08-30-2007 07:43 PM |
