Discuss
GE Dryer
 in
Dryer Repair
My dryer is squeaking when it is drying. The heavier the load the louder it squeaks. What could be causing
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Dryer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-14-2008, 02:50 PM
tmatthews tmatthews is offline
Junior Member
tmatthews is on a distinguished road
Default GE Dryer
Model Number: DJSR473ET6WW   Brand: GE   Age: 5 - 10 years
My dryer is squeaking when it is drying. The heavier the load the louder it squeaks. What could be causing this?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-14-2008, 06:48 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Squeaky rear drum bearing most likely
Let me see if I can write down what the sound is you hear
Eeeeooop Eeeeooop Eeeeooop
let me find you a picA GE Rear bearing.jpgThis guy right here is less than 10 bucks and it mounts on the rear bearing assembly. To access it you gotta remove the front panel and drum. Open the door and remove the screws located at the top, then raise the top and remove the panel. Get the drum out this part mounts on the tip of the drum center.
  #3 (permalink)
Old 05-29-2008, 08:36 AM
juliaannm juliaannm is offline
Junior Member
juliaannm is on a distinguished road
Default
Hello...i Am Having The Similiar Problem...my Dryer Squeaks Horrbily (high Pitched) With A Wet Load But If It Is Dry And Just Dewrinkling Or 1 Or Two Pieces Wet Then No Noise...do You Still Think It Is Just The Rear Bearing? Thanks.
  #4 (permalink)
Old 05-29-2008, 01:34 PM
Senior Expert
APP Volunteer
Default High pitch squeal=rear bearing
A dryer like this makes 2 diff noises of distintion, one is the above mentioned. The other is that of a car that needs rear brakes, Metal to metal scrubbing. Squeal=rear bearing, scrub= drum slides.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
