Discuss
GE dryer timer won't advance in auto mode
 in
Dryer Repair
My GE electric dryer timer won't advance in the automatic modes.(DRXR473EWOWW). I replaced the timer in a recent purchase from
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE dryer timer won't advance in auto mode
  #1 (permalink)
Old 02-20-2010, 11:28 AM
Junior Member
jwysocky is on a distinguished road
Default GE dryer timer won't advance in auto mode
Brand: GE   Age: 5 - 10 years
My GE electric dryer timer won't advance in the automatic modes.(DRXR473EWOWW). I replaced the timer in a recent purchase from APP.com. The dryer dries in all modes, but the timer only advance in the timed drying mode which is OK, so it is usable. I see in the parts list a resistor and thermostats, but have no idea where to go from here. I've cleaned all the duct work front and back.
John
Ads By Google
  #2 (permalink)
Old 02-23-2010, 06:40 AM
Junior Member
Default
Come on guys, someone must have an idea of whats wrong.
John
  #3 (permalink)
Old 02-23-2010, 07:14 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Cannot find any info using given model number.
When you replaced the timer did you find the wiring diagram in the control console?
How this often works is that in Auto modes the timer motor gets power through the heating coil when the heating coil is turned off.
The resistor you mentioned may be there to drop the heater voltage from 240 to 120 for the timer motor.
Remove it and check it for continuity, usually 5,000 to 10,000 ohms.
Also check that the temp settings actually change the temperatures.
You may have a grounded element re: the element never turns off.
__________________
  #4 (permalink)
Old 02-23-2010, 07:25 AM
Junior Member
Default
DRXR473EWOWW This number is listed above.
I have the wiring diagram and will check the resister. If you put the auto near the end of the cycle it will work and the heat will not be on.
Thank you John
  #5 (permalink)
Old 02-23-2010, 08:19 AM
Senior Expert
APP Volunteer
Default
Yes I saw the model number just cannot find any info.
Does sound like it may be a grounded element, wish I had the wiring diagram.
At the end of an Auto cycle the unit goes into cool down to prevent wrinkling and shuts the heater off using a set of timer contacts.
Note: Some GE's use dual elements so if one of them burns out you will stall have heat but no timer advance.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
__________________
  #6 (permalink)
Old 02-23-2010, 09:52 AM
Junior Member
Default
If you have a fax no. I can fax wiring diagram to you if that will help. the wiring diagram does show a inner and outer heating coil. My question is do I remove a side panel to get to the heating element?
  #7 (permalink)
Old 02-23-2010, 02:20 PM
Senior Expert
APP Volunteer
Default
Often you can get at them from the top depending on the dryer.
Perhaps the following will help
http://www.applianceaid.com/ge-dryers.html
__________________
  #8 (permalink)
Old 02-25-2010, 02:54 PM
Junior Member
Default
If it happens to be a heating element, I'm not going to put another $200 into and old washer. I already made a mistake thinking it was the timer $80 dollar latter I'm no further ahead and a Repairman will probable be in the $400 range.. I just keep using it till the other heating element quits. thanks for trying
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry dspeidel Dryer Repair 6 08-25-2009 02:23 PM
Timer does not advance in auto mode rman Dryer Repair 1 06-27-2009 01:39 PM
Timer does not advance in auto dry mode Teager Dryer Repair 8 06-19-2009 04:27 AM
Dryer timer wont advance in automatic mode player4 Dryer Repair 1 02-07-2009 03:24 AM
GE Dryer- Timer will not advance in Auto dalbers Dryer Repair 0 12-09-2008 06:36 PM
