| » Dryer does not heat |
Model Number: LHE5800N0 Brand: Whirlpool Age: More than 10 years
My dryer (whirlpool model # LHE580 0N0 serial # M95024350)was not heating so they told me to replace the thermal fuse. ordered a thermal fuse (part # 3390719) but now i can not find a diagram for my dryer anywhere. please help me find where to install it, thanks
Ron Ads By Google Related Models |
Take off the back and see if it is not right there.
You should know that the problem is not in the thermal fuse if the machine continues to run. First check to make sure you are getting 120v to each side of the connection block. Then disconnect the machine to work on it. I would change out the thermostat, high limit thermostat and thermal cutoff if one of them is bad. Also clean out the internal and external vent areas thoroughly as that is what usually causes the fuses to blow.
__________________
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
