Discuss
honeydothis
 in
Dryer Repair
Thanks for the reply, but the door switch is ok. open the door and nothing happens (no clicking) solenoid works
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » honeydothis
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-13-2008, 08:01 PM
honeydothis honeydothis is offline
Junior Member
honeydothis is on a distinguished road
Default honeydothis
Model Number: LGR4634E   Brand: Whirlpool   Age: 5 - 10 years
Thanks for the reply, but the door switch is ok. open the door and nothing happens (no clicking) solenoid works when you close the door and advance timer to a time setting. Press the start button and you will hear itclick as if it will come on motor doesn't start. It's late here so tomorrow the tub comes out and I check the power to the motor.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-14-2008, 11:47 AM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default remove the back panel to get to the fuse
The fuse mounts on the blower housing to the left of the machine. It looks like this:fuse 2.jpgJust replacing it will make it run again but failure to remove lint from dryer will result in fuse blowing again and again. This includes the filter housing. Sometimes the filter housing itself can be so clogged it has to be removed and washed out.
  #3 (permalink)
Old 05-14-2008, 01:32 PM
Junior Member
Thumbs up honeydothis
After I took the front off and the tub out, I saw that it needed a good vaccuum so I cleaned it well of dust and lint that had made it's way to the motor. I made a jumper wire for the door switch and tried the start button with no progress. I took a can of electric motor cleaner and sprayed the armature and bearing area's and now it works like a charm. Final test will be the load of towels my daughter left us to do!
Thanks Folks. It's nice to go on line to save a few tight $$$ right...
Honeydothis~~~now
  #4 (permalink)
Old 05-15-2008, 01:56 PM
Junior Member
Cool honeydothis
UTT-OH in the dog house again!!! The dryer ran two loads and didn't completely dry 2nd load (But it was a heavy wet load of towells). Any way I took the front off this time and bypass the door switch with a jumper, set time for 45" adn hit the start button,,,only a click again. It's calling for the motor to run but motor isn't. I tapped on the black box on the front of the motor and heard a light click like a reset going off. Well the dryer is a drying with my work clothes. Is it that black box and is it available.
Honey do this ~~~~over
  #5 (permalink)
Old 05-15-2008, 07:07 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
not to my knowledge, i would replace motor ,less headache
__________________
  #6 (permalink)
Old 05-15-2008, 07:38 PM
Junior Member
Default
How much time to change out the motor? I can fix almost anything as I install complete water systems. sure this is different but with steel knee's It's hard to get down. It still worked after a time out of 6 hours to finish drying work cloths. Another thumbs up for now!
Honeydothis
  #7 (permalink)
Old 05-16-2008, 11:11 AM
Senior Expert
APP Volunteer
Default
under an hour
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
honeydothis honeydothis Dryer Repair 1 05-13-2008 07:08 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
