Discuss
timer won't turn
 in
Dryer Repair
I don't know if I did this correctly. I'm trying to find out what could be wrong with my dryer?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » timer won't turn
  #1 (permalink)
Old 05-13-2008, 07:04 PM
Junior Member
Mark Mccreery is on a distinguished road
Default timer won't turn
Model Number: lgr5620kq1   Brand: Whirlpool   Age: 1 - 5 years
I don't know if I did this correctly. I'm trying to find out what could be wrong with my dryer? I went to sears service center told them my timer was'nt turning they said it was bad ordered part from A.P.P. What happens is when you push the start button the burner will light then it kicks off like it should then the timer won't move never heats up again but drum keeps turning. I checked for continuity across t/stats safeties. I don't know the names of dryer parts theirs a safety devise in the blower housing has 2 violet wires going to it and 2 red get continuity through red but not violet could'nt figure out if it was no or nc or if that was even the problem please help very low on cash can't aford another wrong part.
Ads By Google
Related Models
Whirlpool LGR5620KQ1 GAS DRYER
Whirlpool LGR5620KQ2 29"GAS DRYER
Whirlpool LGR5624BN0 GAS DRYER
Whirlpool LGR5624BN1 GAS DRYER
Whirlpool LGR5624BN2 GAS DRYER
Whirlpool LGR5624BW0 GAS DRYER
Whirlpool LGR5624BW1 GAS DRYER
Whirlpool LGR5624BW2 GAS DRYER
Whirlpool LGR5624DQ0 DRYERS
Whirlpool LGR5624DQ1 DRYER
Whirlpool LGR5624DW1 DRYER
Whirlpool LGR5624DZ0 DRYERS
Whirlpool LGR5624DZ1 DRYER
Whirlpool LGR5634AN0 GAS DRYER
Whirlpool LGR5634AQ0 GAS DRYER
Whirlpool LGR5634AQ1 GAS DRYER
Whirlpool LGR5634AQ2 GAS DRYER
Whirlpool LGR5634AW0 Residential Dryer
Whirlpool LGR5634DQ1 DRYER
Whirlpool LGR5634EQ0 GAS DRYER
Whirlpool LGR5634EZ0 GAS DRYER
Whirlpool LGR5634LQ0 RESIDENTIAL DRYER
Whirlpool LGR5635LQ0 29"GAS DRYER
Whirlpool LGR5635LQ1 29"GAS DRYER
Whirlpool LGR5636DW0 DRYER
Whirlpool LGR5636DW1 DRYER
Whirlpool LGR5636EQ0 DRYER
Whirlpool LGR5636EQ1 DRYER
Whirlpool LGR5636EQ2 DRYER
Whirlpool LGR5636EQ3 DRYER
Whirlpool LGR5636EZ0 DRYER
Whirlpool LGR5636EZ1 DRYER
Whirlpool LGR5636EZ2 DRYER
Whirlpool LGR5636EZ3 DRYER
Whirlpool LGR5636JQ0 DRYER
Whirlpool LGR5636JQ1 DRYER
Whirlpool LGR5636JT0 DRYER
Whirlpool LGR5636JT1 DRYER
Whirlpool LGR5636KQ0 DRYER
Whirlpool LGR5636KQ1 DRYER
Whirlpool LGR5636KT0 DRYER
Whirlpool LGR5636KT1 DRYER
Whirlpool LGR5636LG0 RESIDENTIAL DRYER
Whirlpool LGR5636LQ0 RESIDENTIAL DRYER
Whirlpool LGR5636LQ1 29"GAS DRYER
Whirlpool LGR5636LT0 RESIDENTIAL DRYER
Whirlpool LGR5636LT1 29"GAS DRYER
Whirlpool LGR5636LW0 RESIDENTIAL DRYER
Whirlpool LGR5636PQ0 29"GAS DRYER
Whirlpool LGR5636PQ1 29"GAS DRYER
Whirlpool LGR5636PT0 29"GAS DRYER
Whirlpool LGR5636PT1 29"GAS DRYER
Whirlpool LGR5638AN1 GAS DRYER
Whirlpool LGR5638AN2 GAS DRYER
Whirlpool LGR5638AN3 GAS DRYER
Whirlpool LGR5638AW0 Residential Dryer
Whirlpool LGR5638AW1 GAS DRYER
Whirlpool LGR5638AW2 GAS DRYER
Whirlpool LGR5638AW3 GAS DRYER
Whirlpool LGR5644AN1
Whirlpool LGR5644AN2 GAS DRYER
Whirlpool LGR5644AW0 Residential Dryer
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2 GAS DRYER
Whirlpool LGR5644EQ0 GAS DRYER
Whirlpool LGR5644EQ1 DRYERS
Whirlpool LGR5644EQ2 GAS DRYER
Whirlpool LGR5644EQ3 GAS DRYER
Whirlpool LGR5644EZ0 GAS DRYER
Whirlpool LGR5644EZ1 DRYERS
Whirlpool LGR5644EZ2 GAS DRYER
Whirlpool LGR5644EZ3 GAS DRYER
Whirlpool LGR5644JQ0 GAS DRYER
Whirlpool LGR5644JQ1 RESIDENTIAL DRYER
Whirlpool LGR5644JQ2 GAS DRYER
Whirlpool LGR5644JQ3 29" GAS DRYER
Whirlpool LGR5644JT0 GAS DRYER
Whirlpool LGR5644JT1 RESIDENTIAL DRYER
Whirlpool LGR5644JT2 GAS DRYER
Whirlpool LGR5644JT3 29" GAS DRYER
Whirlpool LGR5644PQ0 29" GAS DRYER
Whirlpool LGR5644PQ1 29" GAS DRYER
Whirlpool LGR5700KQ0 DRYER
Whirlpool LGR5700KQ1 DRYER
Whirlpool LGR5700KT0 DRYER
Whirlpool LGR5700KT1 DRYER
Whirlpool LGR5848EQ0 GAS DRYER
Whirlpool LGR5848EQ1 GAS DRYER
Whirlpool LGR5848EQ2 GAS DRYER
Whirlpool LGR5848EQ3 DRYERS
Whirlpool LGR5848EQ4 DRYERS
Whirlpool LGR5848EQ5 GAS DRYER
Whirlpool LGR5848EQ6 GAS DRYER
Whirlpool LGR6611LQ0 RESIDENTIAL DRYER
Whirlpool LGR6611LQ1 29"GAS DRYER
Whirlpool LGR6611PQ0 29" GAS DRYER
Whirlpool LGR6620PQ0 29"GAS DRYER
Whirlpool LGR6620PQ1 29"GAS DRYER
Whirlpool LGR6620PT0 29"GAS DRYER
Whirlpool LGR6620PT1 29"GAS DRYER
Whirlpool LGR6621PQ0 29" GAS DRYER
Whirlpool LGR6634BN0 GAS DRYER
Whirlpool LGR6634BN1 GAS DRYER
Whirlpool LGR6634BN2 GAS DRYER
Whirlpool LGR6634BQ0 GAS DRYER
Whirlpool LGR6634BQ1 GAS DRYER
Whirlpool LGR6634BQ2 GAS DRYER
Whirlpool LGR6634BW0 GAS DRYER
Whirlpool LGR6634BW1 GAS DRYER
Whirlpool LGR6634BW2 GAS DRYER
Whirlpool LGR6634DQ0 GAS DRYER
Whirlpool LGR6634DQ1 GAS DRYER
Whirlpool LGR6634DW0 GAS DRYER
Whirlpool LGR6634DW1 GAS DRYER
Whirlpool LGR6634DZ0 GAS DRYER
Whirlpool LGR6634DZ1 GAS DRYER
Whirlpool LGR6636PW0 29" GAS DRYER
Whirlpool LGR6636PW1 29" GAS DRYER
Whirlpool LGR6638DQ0 GAS DRYER
Whirlpool LGR6638DQ1 GAS DRYER
  #2 (permalink)
Old 05-14-2008, 03:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mark,
Most likely the problem with your dryer caused by a bad gas valve coil (#13 & #14 on the burner break down diagram).
- The part number for the coil kit is AP3094251
Here are the break down diagrams for the Whirlpool dryer Model LGR5620KQ1
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Timer is stuck and won't turn Paul40 Dishwasher Repair 0 01-23-2010 11:36 AM
timer will not turn off lancevancourt Dryer Repair 1 10-17-2009 06:47 PM
Timer won't turn off johnanddebbie20 Dryer Repair 1 09-05-2009 01:44 PM
timer won't advance/turn on at all rwinkless3 Washer Repair 2 09-03-2009 07:51 PM
Timer will not turn off rb8941 Dryer Repair 1 08-01-2007 10:11 PM
