jndwnc
#1 Posted : Wednesday, February 17, 2010 8:12:20 AM(UTC)
jndwnc
The igniter on the dryer would not glow so I replaced the igniter. After replacing the igniter, the igniter glowed but the burner would not light. While assesing the problem I found 2 wires disconnected from the harness, and they were sparking when moved around. One wire is white, with a female plug and the other is blue with a male plug. I am not sure where these wires connect. With the wires loose I am back to the igniter not glowing again. I am not sure if I have shorted out a curcuit or something. I found a male post on on what looks to be some kind of sensor on the barrel around the burner that the white wire could possibly attach to but I do not have any idea where the blue wire might connect.
magician59
#2 Posted : Wednesday, February 17, 2010 11:38:01 AM(UTC)
magician59
Look for a tech sheet inside the console. It should contain a schematic diagram that lists the wire colors, and shows where they're connected.
