| » Dryer squeaks and has no heat |
Model Number: MDE546RES0 Brand: White-Westinghouse Age: 5 - 10 years
My dryer has been squeking for some time now, and 2 weeks ago it stopped blowing hot air. It blows cool air and still squeaks, I would like to figure out what is wrong with it and fix it myself.
Can you help me. |
When this here dryer speaks you must listen. The rear bearing will wear down into the grove and change the position of the tub. The tub will begin to rub against the heating element. Starting to get the picture? Check out this photoa frigidaire dryer bearing failure.jpgYou need to pop the top and remove the tub. If it was the slides then the sound you hear would be simular to bad rear car brakes. If it squeals then the ball is rubbing the metal support and the neck of it is slowly being cut into till sadly it just completely seperates and locks up the tub.
In order to provide most accurate advise we need the complete model number of the dryer.
__________________
Professional appliance repair in Los Angeles, California. |
Remove the front panel and the front bulkhead support and check the glides (#6 on the break down diagram). Check the rear drum support rollers and the idler pulley.
You can find the complete disassembly instructions in the Service manual. Here are the break down diagrams for the Amana dryer Model DLE330RAW Gene.
__________________
The Service manual Gene posted tells you pretty much step by step on how to get to every part of the machine.
The glides tend to wear on these, they are inexpensive and pretty easy to fix. Just follow the manual it's like reading a recipe only you need a screw driver . Trust me if I can do these anyone can!Natalie
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
check it out. you have 2 of these mounted on the front end. When they get thin they cause the drum to rub like bad brakes. a glide.jpg
do this: mtgscrews.jpg
| Display Modes | |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 04:50 PM |
| Dryer No Heat | jg1654 | Dryer Repair | 1 | 05-12-2008 02:52 PM |
| motor squeaks | dennis3271 | Dryer Repair | 2 | 04-14-2008 07:42 AM |
| Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 11:47 AM |
| Dryer Squeaks When Drum Turns | Ruben1 | Dryer Repair | 2 | 10-10-2007 08:31 PM |
