| » Bosch Axis Dryer won't heat |
Model Number: WTL5410UC Brand: Bosch Age: 1 - 5 years
I'm working on a Bosch Axis dryer that won't heat. I've changed the heater element (including overtemp thermal) and the control board which drives the heater. Gets warm but not hot. I don't have documentation for the dryer. There are 2 temp sensors in dryer but not sure where they are. There are 2 sliding probes that contact the drum. Are these the sensors? I looked up parts at Appliance Parts Pros, and they list a temp thermostat, but I don't know where this is either. Anyone familiar with this model who can lend a hand?
Thanks, Paul |
Paul,
Did you clean the heat exchanger (condenser)? It should be cleaned 3-4 times a year. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Hi Gene. Thanks for your reply. No, I haven't cleaned the condenser. Would a dirty condenser prevent the heater from coming on? Also, there is a temp regulator, I believe, mounted somewhere near the dryer door. Would a defective one also prevent the heater from coming on? I see that this sensor plugs directly into X11-2 connector on power module.
Regards, Paul |
Paul,
Lets do one thing at a time. Clean the condenser first and post the result. Gene.
__________________
| Display Modes | |
| Bosch Dryer | redsuspender | Dryer Repair | 2 | 09-25-2008 04:49 PM |
| Bosch Axxis Dryer - No HEAT | explorer5 | Dryer Repair | 0 | 04-28-2008 05:21 PM |
| Bosch Double Oven won't heat | sdevitt | Oven Repair (including Ranges and Cooktops) | 0 | 04-08-2008 06:29 PM |
| Bosch Dryer - No Heat | aroaderick | Dryer Repair | 0 | 03-17-2008 08:09 PM |
| Bosch Dryer | Frank Titoni | Dryer Repair | 0 | 09-01-2007 10:26 AM |
