Discuss
Bosch Axis Dryer won't heat
 in
Dryer Repair
I'm working on a Bosch Axis dryer that won't heat. I've changed the heater element (including overtemp
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Bosch Axis Dryer won't heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-10-2008, 07:35 PM
natale_p natale_p is offline
Junior Member
natale_p is on a distinguished road
Smile Bosch Axis Dryer won't heat
Model Number: WTL5410UC   Brand: Bosch   Age: 1 - 5 years
I'm working on a Bosch Axis dryer that won't heat. I've changed the heater element (including overtemp thermal) and the control board which drives the heater. Gets warm but not hot. I don't have documentation for the dryer. There are 2 temp sensors in dryer but not sure where they are. There are 2 sliding probes that contact the drum. Are these the sensors? I looked up parts at Appliance Parts Pros, and they list a temp thermostat, but I don't know where this is either. Anyone familiar with this model who can lend a hand?
Thanks,
Paul
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-11-2008, 03:20 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Paul,
Did you clean the heat exchanger (condenser)? It should be cleaned 3-4 times a year.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-11-2008, 11:10 PM
Junior Member
Default Bosch Dryer
Hi Gene. Thanks for your reply. No, I haven't cleaned the condenser. Would a dirty condenser prevent the heater from coming on? Also, there is a temp regulator, I believe, mounted somewhere near the dryer door. Would a defective one also prevent the heater from coming on? I see that this sensor plugs directly into X11-2 connector on power module.
Regards,
Paul
  #4 (permalink)
Old 05-13-2008, 09:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Paul,
Lets do one thing at a time. Clean the condenser first and post the result.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Axxis Dryer - No HEAT explorer5 Dryer Repair 0 04-28-2008 04:21 PM
Bosch Dryer redsuspender Dryer Repair 1 04-10-2008 01:42 PM
Bosch Double Oven won't heat sdevitt Oven Repair (including Ranges and Cooktops) 0 04-08-2008 05:29 PM
Bosch Dryer - No Heat aroaderick Dryer Repair 0 03-17-2008 07:09 PM
Bosch Dryer Frank Titoni Dryer Repair 0 09-01-2007 09:26 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
