| » GE Harmony Gas Dryer - Won't Power up Display |
Model Number: DPGT750GC1WW Brand: GE Age: 1 - 5 years
Power up display is dead, will not power up or respond to buttons. Previously a few months ago I had the same problem and pushing the "back" and "my cycles" buttons at the same time (reset) fixed the problem. Not this time. Dryer has power and the drum light comes on. I have taken the electronic control model apart and adjusted all wiring connectors, tapped relays and also adjusted display board connectors. I understand from other posts the thermal fuse causes power up problems, but none seem to be the electronic display dryers. Will the thermal fuse cause the display/button board from powering up? Any way to test the control module or display board?
Any suggestions on where to start and what to do would be appreciated. Model # DPGT750GC1WW Ads By Google Related Models Last edited by venicebeachvillas : 11-08-2010 at 05:50 AM. Reason: Added Icon hoping to get a reply |
The problem previously describe fixed itself by a fluke. Now the problem has reoccurred. Can someone reply on where to look, possible causes and how to verify the main control module and display board.
Please help ASAP. Thanks |
Thanks for the reply. I found a found a service manual which indicated output power pins that supply the display. It was partially dead and intermintent. I too replaced the Main board. It is working now. I sure wish you could get timely replies on the tough problems on this forum.
I had the exact same problem, but got it fixed without spending any money.
-Press BACK & MY CYCLE buttons at the same time for 15 seconds. This will wake up the display but with a statement that there is something wrong, and give you a GE phone number. -Press Power, then Help, then both My Cycles & Back at the same time for 3 seconds, then EXIT from the LCD screen. -My display said there is something wrong with the door switch. I checked the door switch and it was turning the light off and on, so I figured it was ok. I had two options on the LCD screen: EXIT or MORE. I kept pressing MORE until I arrived at a NEW DRYER SETUP button. I pressed it and went through the new dryer setup process and guess what? Problem resolved. Most of this was just fumbling around and getting lucky. I hope someone else is helped by my experience. |
| Display Modes | |
| GE Profile Harmony Dryer | rphaunef | Dryer Repair | 27 | 10-24-2012 10:35 AM |
| GE Profile Harmony Dryer Display-Control not working | Charliz | Dryer Repair | 0 | 01-02-2010 02:23 PM |
| GE Harmony Gas Dryer- No Heat | dbyro | Dryer Repair | 0 | 09-27-2009 08:29 AM |
| GE Harmony Gas Dryer | johnmou | Dryer Repair | 0 | 07-01-2009 11:09 PM |
| Harmony Gas Dryer | johnmou | Dryer Repair | 1 | 06-20-2009 12:37 PM |
