| » Dryer Timer will not advance in Automatic |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: LEB6400LWB Brand: Whirlpool Age: 5 - 10 years
My Whirlpool dryer timer will not advance in the automatic drying mode. The dryer continues to run and get very hot. I thought the problem was the timer so I replaced it . The problem still exists. The dryer works fine in the timed cycles.
remove the little board and clean the contacts on it with a q tip and alchohol. shove it back in and see if that fixes it. This particular dryer(model number not located by the way just guessing from question) if I am right it has a small board mounted near the timer that powers the motor on the timer to advance it towards shut off only after no more moisture is sense inside the rear wall of the dryer by those sensors that mount on a black hump on back wall of the dryer. Just a guess.
| Display Modes | |
| Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes. | XtremeRob | Dryer Repair | 3 | 02-12-2008 07:56 PM |
| Dryer timer fails to advance. | robersonlee | Dryer Repair | 0 | 02-11-2008 12:34 PM |
| Whirlpool dryer timer won't advance | Hzep | Dryer Repair | 1 | 01-28-2008 03:22 PM |
| Kenmore Timer won't advance or shut off | zaq12wsx | Dryer Repair | 1 | 01-19-2008 06:36 PM |
| Timer does not advance | Lloyd Kneller | Washer Repair | 1 | 09-26-2007 02:18 AM |
