Discuss
Dryer Timer will not advance in Automatic
 in
Dryer Repair
My Whirlpool dryer timer will not advance in the automatic drying mode. The dryer continues to run and get very
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Timer will not advance in Automatic
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-10-2008, 09:45 AM
kabgreen kabgreen is offline
Junior Member
kabgreen is on a distinguished road
Default Dryer Timer will not advance in Automatic
Model Number: LEB6400LWB   Brand: Whirlpool   Age: 5 - 10 years
My Whirlpool dryer timer will not advance in the automatic drying mode. The dryer continues to run and get very hot. I thought the problem was the timer so I replaced it . The problem still exists. The dryer works fine in the timed cycles.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-10-2008, 12:30 PM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
(With no load in the dryer)
Disconnect the vent from the back of the
dryer (make sure the lint filter is clean) then
run it on automatic cycle for awhile.
Does the timer still stay in one place?
  #3 (permalink)
Old 05-10-2008, 07:47 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default sensor board has corrosion on it
remove the little board and clean the contacts on it with a q tip and alchohol. shove it back in and see if that fixes it. This particular dryer(model number not located by the way just guessing from question) if I am right it has a small board mounted near the timer that powers the motor on the timer to advance it towards shut off only after no more moisture is sense inside the rear wall of the dryer by those sensors that mount on a black hump on back wall of the dryer. Just a guess.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes. XtremeRob Dryer Repair 3 02-12-2008 07:56 PM
Dryer timer fails to advance. robersonlee Dryer Repair 0 02-11-2008 12:34 PM
Whirlpool dryer timer won't advance Hzep Dryer Repair 1 01-28-2008 03:22 PM
Kenmore Timer won't advance or shut off zaq12wsx Dryer Repair 1 01-19-2008 06:36 PM
Timer does not advance Lloyd Kneller Washer Repair 1 09-26-2007 02:18 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
