Discuss
Electric dryer
 in
Dryer Repair
Dryer stopped heating. Relaced coil-heater; thermal limiter and thermostat-safety. Still no heat any suggestions as to what next?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric dryer
  #1 (permalink)
Old 05-10-2008, 07:13 AM
coysan coysan is offline
Junior Member
coysan is on a distinguished road
Default Electric dryer
Model Number: FDE747RBS1   Brand: Frigidaire   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-10-2008, 08:14 AM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Check your timer next
With the power disconnected trace the thick red wire from the heater up to the timer. At the terminal where that red heater wire connects to the timer is where I suspect the problem is. Remove the wire and check it with a meter. Set the timer to a place where you know it was working before and check between this terminal and all the others on the timer. Somewhere along the way you should get a continuity reading. If you cannot get a reading then that timer is fried.
  #3 (permalink)
Old 05-10-2008, 08:41 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
did you check with your meter, if you have on ,whether youare getting 240 volts coming to dryer. if so there should be a wiring diagram in control panel. that will show you the contacts that would be closed in timer ,you need to set your timer to continuity to do this test .unplug dryer first .set timer to minute cycle
__________________
  #4 (permalink)
Old 05-15-2008, 05:39 AM
Junior Member
Default
tks I'll try! out of town sorry 4 late reply
  #5 (permalink)
Old 09-03-2008, 06:54 PM
douglas j. hoffman douglas j. hoffman is offline
Junior Member
douglas j. hoffman is on a distinguished road
Default I am at the same point with a friends dryer and can't figure it out ???
Quote:
I will write again if I find this solution
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
electric dryer kevin madson Dryer Repair 1 04-08-2008 02:23 PM
electric dryer gwoakley Dryer Repair 3 03-27-2008 10:55 AM
Frigidaire electric dryer outlaw Dryer Repair 1 01-19-2008 07:42 PM
Gas dryer to electric dryer convertion. Fhabeeow Dryer Repair 1 01-08-2008 08:49 PM
Electric Dryer too hot jim k Dryer Repair 3 07-25-2007 05:43 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
