Discuss
Inconsistent flame ignition
 in
Dryer Repair
I have a 1978 Whirlpool gas dryer with five temperature settings and three drying cycles. The problem is that the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Inconsistent flame ignition
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-10-2008, 05:55 AM
bgredd2000 bgredd2000 is offline
Junior Member
bgredd2000 is on a distinguished road
Default Inconsistent flame ignition
Model Number: LHE-7501   Brand: Whirlpool   Age: More than 10 years
The problem is that the burner does not consistently light. Here is what it does: The dryer starts, the igniter rod glows and the gas valve turns on and initially lights the flame. This will happen for a few cycles and then the gas valve will not kick on. I have replaced the igniter sensor switch on the outside of the combustion chamber funnel and the igniter cycles like it suppose to (glows bright orange every couple minutes) but the gas valve is not tripping on.
The only other thing that I found was a wad of lint and tissue wrapped around the thermocouple in the exhaust - that has been cleared out.
The dryer is in otherwise excellent condition - seals on the drum and the drive belt were replaced a couple of years ago. I would really like to keep the thing running.
Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-10-2008, 05:47 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad coils on the gas valve.
- The part number for the coil kit is AP2150379
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-10-2008, 07:34 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Oh OH them coils
these dudesdryer coil kit.jpg will work once and not any more for a while then work once and quit again. Like my son in law
  #4 (permalink)
Old 05-11-2008, 12:01 PM
Junior Member
Smile Coils indeed!
It was a coil. I was testing the coils and found one that was intermitent.....would lose continuity when I wiggled the wires.
Gene - Unfortunately I could not use the part you specified because I have the old style 3-part solenoid assembly. Luckily I found a place that can send me one - though it is much more expensive.
Thanks for your help!
Dick D.
  #5 (permalink)
Old 05-11-2008, 04:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Dick,
The model number you posted leads to the electric dryer and not the gas, so I gave you the part number for most common coil kit. If you can post the right model number, I probably can find this part in the APP data base with better price.
__________________
  #6 (permalink)
Old 05-11-2008, 07:46 PM
Junior Member
Default Correct Model Number
Gene -
The origianl model number posted was off the first page of the generic manual that I had in my files. The actual model number on the machine is LHI-7501NO.
This correct model number has not worked on any of the site that I've tried - the sites direct me to a different model number (LHI-7501WO) that shows the wrong gas valve.
Would be very interested if you can find the correct parts list.
Dick D.
  #7 (permalink)
Old 05-12-2008, 06:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Dick,
The letters "W" & "H" in the model number is just a color identifiers. "W" - white and "N" - almond.
According to the information I found Whirlpool redesigned the gas valve for this dryer together with new style of coil due to safety issue., what means you have to replace the whole gas valve & burner assembly.
- The part number for the gas valve & burner assembly is AP3094285
Here are the break down diagrams for the Whirlpool dryer Model LHI7501W0
P.S. Because of price for the part your decision should be based on the condition of the dryer.
__________________
  #8 (permalink)
Old 05-13-2008, 04:15 AM
Junior Member
Default
Gene - Thanks for the additional information - that's not the kind of information that a person is going to find just anywhere.
Not sure what I'm going to do - the price tag is giving me pause. It may be time to bite the bullet and retire the unit.
I appreciate all your help in diagnosing the problem.
Best Regards,
Dick D.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
burner ignition has a mind of its own Laura Oven Repair (including Ranges and Cooktops) 2 04-21-2008 01:57 PM
Frigidaire Gas Dryer - heat inconsistent futbol79 Dryer Repair 3 04-15-2008 02:23 AM
Gas range ignition problem wblazei Oven Repair (including Ranges and Cooktops) 1 03-29-2008 12:23 PM
dryer heat is inconsistent sblylck Dryer Repair 1 10-25-2007 02:27 AM
Inconsistent temperature frig & freez vrocrider Refrigerator & Freezer Repair 1 09-14-2007 02:09 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
