Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Maytag Thermostat Part(s) - which one? (http://forum.appliancepartspros.com/dryer-repair/78393-maytag-thermostat-part-s-one.html)
backbeat 02-11-2010 06:57 AM
Hello,
I have a problem with auto dry cycles, where the dryer stays on and the timer stays in the same position. I replaced the timer, so it would appear that I have two thermostats to check and/or replace, as well as a radiant sensor. I'm checked the high-limit thermostat and it's not 'open'. I don't know how to check the other thermostat, as it has five wires connected to it. I also checked the radiant sensor, and that too was not 'open'.
The part numbers I got from customer service are:
High Limit: AP4036956
Multi-Thermostat?: AP4037199
Can you help?
Thanks!
