Discuss
Dryer malfunction
 in
Dryer Repair
The gas dryer is electrically energized and hums, although the drum doesn't turn, when the door is closed or
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer malfunction
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-08-2008, 11:01 AM
tomted1 tomted1 is offline
Junior Member
tomted1 is on a distinguished road
Default Dryer malfunction
Model Number: DDG7980GELAD   Brand: GE   Age: More than 10 years
The gas dryer is electrically energized and hums, although the drum doesn't turn, when the door is closed or open. The only method of turning it off is to either set the timer to zero or unplug it. The drum doesn't turn when the door is closed and the timer has minutes on it. Pushing the start button makes no difference.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-08-2008, 12:14 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
check to see if drum belt is broken. possible motor problem if belt not broken
__________________
  #3 (permalink)
Old 05-08-2008, 01:02 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Open the rear access panel
Look in and see if the belt is broken. From what you are describing it sounds like the gas assembly is trying to fire but the drum ain't turning. To replace the belt you are gonna have to remove the front panel. You may as well give it a good cleaning while you are at it. Also inspect the slides and rear bearing.
  #4 (permalink)
Old 05-08-2008, 01:58 PM
Junior Member
Default
Thanks mfa and SMJW but why would the motor be energized when the door is closed?
  #5 (permalink)
Old 05-08-2008, 03:03 PM
Senior Expert
APP Volunteer
Default the centrifugal switch is stuck.
when you shut the door the gas trys to work . must be getting power through that switch. I have seen it. Check the motor swtch. One that old might be all full of stuff and sticking. Did you break down the dryer yet? Get the drum out, clean and inspect the motor.
  #6 (permalink)
Old 05-08-2008, 10:59 PM
Junior Member
Default
OK, back from work and able to flip front panel and see that the belt is in place. I guess I'll look to the motor. It is nearly 18 years old so that wouldn't be too surprising. Hmmm, if it's the motor, do I replace it or buy a new dryer? I've replaced the slides and rear bearing, some gas valve parts and been through a couple of igniters over the years.
  #7 (permalink)
Old 05-09-2008, 04:39 AM
Senior Expert
APP Volunteer
Default A good old style dryer like that is worth replacing the motor.
These newer appliances are not worthy to stand next to a fine old machine like that. The motor is really the heart of the dryer. I would definately replace it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Igniter Malfunction hec2832pa Oven Repair (including Ranges and Cooktops) 0 04-23-2008 08:41 AM
GE Profile Malfunction AngieAH Washer Repair 4 12-21-2007 05:20 PM
Dishwasher Software Malfunction? ships380 Dishwasher Repair 2 11-19-2007 09:27 AM
Whirlpool dishwasher malfunction rick Dishwasher Repair 1 07-30-2007 04:26 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
