Discuss
Heat in Air Only Cycle
 in
Dryer Repair
The heating element is activated and emits a low heat when Air Only is selected from the menu option. In
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Heat in Air Only Cycle
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-07-2008, 05:10 PM
masd masd is offline
Junior Member
masd is on a distinguished road
Question Heat in Air Only Cycle
Model Number: GEW9200LWO   Brand: Whirlpool   Age: 5 - 10 years
The heating element is activated and emits a low heat when Air Only is selected from the menu option. In addition, High heat was measured at 155 degrees, Med heat 140 degrees, low heat 132 degrees and extra low heat 128-130 degrees, and air only at 128 degrees. I have replaced the heating element, the thermistor, the thermal cut-off, the thermostat, thermal fuse, and the machine control electronics board. I did all this within the last 2 weeks since the initial problem was the heating element was burned out (broken element). Do you have any idea what the issue is and what actions I need to take to correct the problem?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-07-2008, 08:14 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
problem maybe themistor to the right of thermal fuse on blower housing .i usually carry that part when i hear about that problem . part#ap3919451
__________________
  #3 (permalink)
Old 05-08-2008, 04:54 AM
Junior Member
Default heat in air only cycle
I replaced the thermistor and that did not fix the problem
  #4 (permalink)
Old 05-08-2008, 08:03 AM
Senior Expert
APP Volunteer
Default
check wiring harness at control board under top of dryer .are there any error codes
__________________
  #5 (permalink)
Old 05-11-2008, 09:11 AM
Junior Member
Default Found issue
The issue was that the heating element was grounding out against the metal heat box. Lesson learned check and make sure heating element is secure on white installation fittings.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No or limited heat during drying cycle roles120 Dryer Repair 4 09-11-2008 03:06 PM
Gas Dryer doesn't heat during cycle castillocm Dryer Repair 0 04-29-2008 11:17 AM
Dishher stuck in water heat cycle james jones Dishwasher Repair 0 04-19-2008 03:08 PM
Dryer won't heat up runs continually in automatic cycle John8 Dryer Repair 0 03-21-2008 07:46 AM
Washer fills on wash cycle and rinse cycle and won't stop filling! riphinney Washer Repair 15 03-12-2008 05:30 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
