| » Heat in Air Only Cycle |
Model Number: GEW9200LWO Brand: Whirlpool Age: 5 - 10 years
The heating element is activated and emits a low heat when Air Only is selected from the menu option. In addition, High heat was measured at 155 degrees, Med heat 140 degrees, low heat 132 degrees and extra low heat 128-130 degrees, and air only at 128 degrees. I have replaced the heating element, the thermistor, the thermal cut-off, the thermostat, thermal fuse, and the machine control electronics board. I did all this within the last 2 weeks since the initial problem was the heating element was burned out (broken element). Do you have any idea what the issue is and what actions I need to take to correct the problem?
problem maybe themistor to the right of thermal fuse on blower housing .i usually carry that part when i hear about that problem . part#ap3919451
__________________
| Display Modes | |
| No or limited heat during drying cycle | roles120 | Dryer Repair | 4 | 09-11-2008 04:06 PM |
| Gas Dryer doesn't heat during cycle | castillocm | Dryer Repair | 0 | 04-29-2008 12:17 PM |
| Dishher stuck in water heat cycle | james jones | Dishwasher Repair | 0 | 04-19-2008 04:08 PM |
| Dryer won't heat up runs continually in automatic cycle | John8 | Dryer Repair | 0 | 03-21-2008 08:46 AM |
| Washer fills on wash cycle and rinse cycle and won't stop filling! | riphinney | Washer Repair | 15 | 03-12-2008 06:30 PM |
