| » something in lint trap |
Model Number: 471 49012890 Brand: Frigidaire Age: 1 - 5 years
I just got this, it worked fine but I noticed there is no lint trap, so I began fishing lint out of the hole, I pulled out quite a bit of lint, wrappers and a sock, I ordered a new lint trap, but I think there may be more inside, how do I check, how can I take the dryer back off to see also if there is a build up of lint inside, there was some around the drum when I looked through the small door on the back. I dont want to ruin this dryer.
Related Models |
You work from the front to fix this puppy.
pop the top and remove the front. Get the tub out. the element is located on the rear of the dryer. The element can be restrung for a lot cheaper price than buying the whole pan with element attached.gibsonfrig elec coil.jpg |
Go along the outer edge between the front and the top and use a putty knife. Press against the clips located 2 inchs from either side of the dryer. while lifting upwards on the top. It should just release.top removal.jpg
| Display Modes | |
| Lint Screen Housing | chetterogo | Dryer Repair | 3 | 04-24-2008 06:24 PM |
| Toy dropped down lint chute | bell | Dryer Repair | 1 | 02-25-2008 10:33 AM |
| How do I remove manifold trap from tub? | Sensible | Washer Repair | 2 | 02-17-2008 10:50 AM |
| LINT in washer and dryer | BB69 | Washer Repair | 1 | 11-14-2007 07:45 PM |
| Lint Filter problem | Dan Pearl | Dryer Repair | 1 | 11-08-2007 04:55 PM |
