Discuss
Gas Dryer no Heat
 in
Dryer Repair
A friend of mine gave me this Maytag gas dryer about a year ago and it was working just fine
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer no Heat
  #1 (permalink)
Old 08-28-2007, 02:21 PM
KrazyK55 KrazyK55 is offline
Junior Member
KrazyK55 is on a distinguished road
Question Gas Dryer no Heat
Model Number: MDG3000AWA   Brand: Maytag   Age: 1 - 5 years
A friend of mine gave me this Maytag gas dryer about a year ago and it was working just fine when we unhooked it. I didn't need it at the time but since mine was pretty old I figured since it was free that it couldn't hurt to have a spare. It has been sitting in my basement unused for about a year until I hooked it up yesterday but, it won't heat up. It runs fine and I can see the glow from the igniter but no ignition or heat. I rechecked the gas supply line and it is fine and as I said, the dryer runs and the controls work but no heat. What could have gone bad just sitting? Coils, Gas valve? Burner? I'm open to suggestion.
Thanks,
Dave:
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-28-2007, 05:54 PM
jerryk jerryk is offline
Junior Member
jerryk is on a distinguished road
Default
gas dryer has no heat
  #3 (permalink)
Old 08-29-2007, 08:46 AM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Krazy,
Sounds like one of three things: 1. gas valve coils 2. gas valve 3. no gas to the valve (check shut off valve inside the dryer).
  #4 (permalink)
Old 08-29-2007, 05:09 PM
Junior Member
Default Re gas Dryer no Heat
Ok thanks I didn't know if those parts could go bad from just setting or not so, I'll check them out.
  #5 (permalink)
Old 01-15-2008, 01:49 PM
OKIEDOC OKIEDOC is offline
Junior Member
OKIEDOC is on a distinguished road
Default
I am having somewhat the same problem. The dryer works just fine when you first turn it on then when it is time for the heat to come back on during the cycle there is nothing. The igniter glows for a time then goes out. If I stop the dryer for about 15 minute the restart the heat comes back on, what could be the problem.
  #6 (permalink)
Old 01-15-2008, 01:57 PM
Junior Member
Question Maytag Dryer
I have a MAYTAG gas dryer MOD LDG8904AAE. When I first turn on the dryer works just fine. During the cycle the burner will shut down and will not come back on. The igniter will glow red for a time but the burner will not ignite. I can shut down the dryer for a few minutes and then turn on again and it will work fine for a while until it shuts off. What could be the problem.
  #7 (permalink)
Old 01-15-2008, 02:22 PM
mr.vman mr.vman is offline
Junior Member
mr.vman is on a distinguished road
Default No Dryer heat
I am having a similiar problem on my Maytag dryer, LDG7304AAE. The gas will come on, and light then the Hi limit Stat will click and turn the gas off. Replaced the hi limit stat, still turns off. Could it be the burner assembly or the gas valve? The flame takes up the entire combustion chamber, everything is clean, no clogs in the stack into the tub. Possible burner worn out (14 years old). I don't see a way to adjust the flame. Should the flame stay on with the front cover on, or does it heat the Hi limit stat? Even put the cover back on and can hear it click off.
Thanks, Steve V.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will run but not heat allansc Dryer Repair 12 12-28-2007 07:10 PM
dryer will not heat? radio963 Dryer Repair 1 11-09-2007 10:02 AM
gas dryer with no heat lz7274 Dryer Repair 1 08-22-2007 05:02 PM
Dryer won't heat dwh Dryer Repair 1 07-30-2007 06:35 PM
dryer heat karen Dryer Repair 0 07-23-2007 01:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
