I have to push in on switch and move it around to get the motor to kick on. I have the cabinet apart and the motor is running free but when timer switch moves to certain spots on the dial the motor will stop running and then wiggle the timer switch to a different spot and will start again. Is my problem in this switch or somewhere else?:confused: Also I had a broken belt when I opened the cabinet hopefully unrelated.
