Discuss
Electric Dryer is slow to dry
 in
Dryer Repair
I noticed a while back that it takes a while for my clothes to dry. The Automatic setting does not
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric Dryer is slow to dry
  #1 (permalink)
Old 02-09-2010, 02:37 PM
Junior Member
amonard is on a distinguished road
Default Electric Dryer is slow to dry
Model Number: ALE866saw   Brand: Amana   Age: 5 - 10 years
I noticed a while back that it takes a while for my clothes to dry. The Automatic setting does not work as it shuts off before the clothes are dry. In a average load I now use the timer function. I set it to 70 min then I put it in for another 20-30 min. I tested it on automatic today and put a wet wash cloth in the dryer. On automatic it ran for 20-30 minutes then shut off. The wash cloth was about 50% dry.
A year ago I took the dryer apart and cleaned the inside and made sure that the vent pipe was clean. Nothing out of the ordinary to report. I also checked the resistance on the heater. I can not remember the readout but I remember that it was not shorted.
Ads By Google
Related Models
Amana ALE866SAW DRYER- ELE
Amana ALE866SBC DRYER- ELE
Amana ALE866SBW DRYER- ELE
Amana ALE866SCW DRYER- ELE
Amana ALE868QAW DRYER- ELE
Amana ALE868QCW WASHER-TOP LOADING
Amana ALE956EAC DRYER- ELE
Amana ALE956EAW DRYER- ELE
Whirlpool ALF12420 Air-conditioner/heat pump
Whirlpool ALF15040 Air-conditioner/heat pump
Whirlpool ALF20040 Air-conditioner/heat pump
Whirlpool ALF21040 Air-conditioner/heat pump
Whirlpool ALF24040 Air-conditioner/heat pump
Whirlpool ALFH0820 Air-conditioner/heat pump
Amana ALG120RAW DRYER- GAS
Amana ALG230RAW DRYER- GAS
Amana ALG230RCW DRYER- GAS
Amana ALG331RAC DRYER- GAS
Amana ALG331RAW DRYER- GAS
Amana ALG331RMC DRYER- GAS
Amana ALG331RMW DRYER- GAS
Amana ALG443RAC DRYER- GAS
Amana ALG443RAW DRYER- GAS
Amana ALG443RCW DRYER- GAS
Amana ALG565SAC DRYER- GAS
Amana ALG565SAW DRYER- GAS
Amana ALG643RAC DRYER- GAS
Amana ALG643RAW DRYER- GAS
Amana ALG643RBC DRYER- GAS
Amana ALG643RBW DRYER- GAS
Amana ALG643RMC WASHER-TOP LOADING
Amana ALG643RMC DRYER- GAS
Amana ALG643RMC1 WASHER-TOP LOADING
Amana ALG643RMW WASHER-TOP LOADING
Amana ALG643RMW DRYER- GAS
Amana ALG643RMW1 WASHER-TOP LOADING
Amana ALG665SAC DRYER- GAS
Amana ALG665SAW DRYER- GAS
Amana ALG866SAC DRYER- GAS
Amana ALG866SAW DRYER- GAS
Amana ALG866SBC DRYER- GAS
Amana ALG866SBW DRYER- GAS
Amana ALG866SCW DRYER- GAS
Amana ALG868QAW DRYER- GAS
Amana ALG868QCW WASHER-TOP LOADING
Amana ALG956EAC DRYER- GAS
Amana ALG956EAW DRYER- GAS
Whirlpool ALJ00520 Air-conditioner/heat pump
Whirlpool ALJ07520 Air-conditioner/heat pump
Whirlpool ALJ10020 Air-conditioner/heat pump
Whirlpool ALJ12020 Air-conditioner/heat pump
Whirlpool ALJ18040 Air-conditioner/heat pump
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
Admiral ALR5715QDW RANGE- S/C F/S GAS
Amana ALW110RAW WASHER-TOP LOADING
Amana ALW210RAW WASHER-TOP LOADING
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMC WASHER-TOP LOADING
Amana ALW210RMW Washer - Top Loading
Amana ALW210RMW WASHER-TOP LOADING
Admiral ALW221RJW WASHER-TOP LOADING
Amana ALW410DAW WASHER-TOP LOADING
Amana ALW430RAC WASHER-TOP LOADING
Amana ALW430RAW WASHER-TOP LOADING
Amana ALW432RAW WASHER-TOP LOADING
Amana ALW450QAC WASHER-TOP LOADING
Amana ALW450QAW WASHER-TOP LOADING
Amana ALW480DAC WASHER-TOP LOADING
Amana ALW480DAW WASHER-TOP LOADING
Amana ALW540RAC WASHER-TOP LOADING
Amana ALW540RAW WASHER-TOP LOADING
  #2 (permalink)
Old 02-11-2010, 11:36 AM
Junior Member
Default
Today I did a temp. test. I stuck a thermometor in the dryer near the lent trap. I ran on a timer setting on Fabric selector High, the temp ranged from 140-160. I did the same on Med and Low and got the same results. Is there suppose to be that much range in temp drop when on high? Is my fabric selector broke as it does nothing different on Med and Low? Can a Thermostatbe the issue responding to temps other than it was designed for?
  #3 (permalink)
Old 02-11-2010, 02:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Get rid of the cycling thermostat heater (#11 on the diagram) and replace the cycling thermostat with the new thermostat with built in heater and four terminals. Connect the wires from the old thermostat heater to the smaller terminals on the new thermostat.
Check the blower wheel. Make sure it's not slipping on the motor shaft.
- The cycling thermostat Part number: AP2402249
- The blower wheel Part number: AP4062362
Here are the breakdown diagrams and Replacement parts for AMANA ALE866SAW Dryer - Ele | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 02-11-2010, 04:12 PM
Junior Member
Default
Any reason why I should not use Part Number: AP4053749 made by WHIRLPOOL
I only ask because it is half the price.
Enlarge Photo
THERMOSTAT
Enlarge Photo
THERMOSTAT
  #5 (permalink)
Old 02-11-2010, 07:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The thermostat Part number: AP4053749
requires the thermostat heater Part number: AP4070513
to be replaced as well.
The price for these two parts is higher than price for the thermostat I've recommended.
__________________
  #6 (permalink)
Old 03-01-2010, 12:24 PM
Junior Member
Default
Gene the Cycling Thermostat worked. It is drying faster than ever and the change of temperature from when the heater is on vs off is narrower than before. However the automatic cycle does not work. Clothes go in and come out very wet. I doubt it stays on for 20 min. Where is the part to tell it to turn off based on humidity?
  #7 (permalink)
Old 03-02-2010, 07:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
...However the automatic cycle does not work. Clothes go in and come out very wet. I doubt it stays on for 20 min...
In can be caused by a bad moister sensing board (#5 on the diagram). You can test it as described in the Service manual (page 14).
- The moister sensing board Part number: AP4048505
__________________
  #8 (permalink)
Old 03-22-2010, 02:58 PM
Junior Member
Thumbs up Fixed
I replaced the moister sensing board and it worked. My dryer is back to working condition. Problems solved. Thanks Gene.
  #9 (permalink)
Old 03-22-2010, 03:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad you were able to fix it. Thank you for the feed back.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 70 series dryer is slow to dry. borger10 Dryer Repair 6 06-11-2013 06:34 AM
noisey dryer slow to dry Don OBrian Dryer Repair 3 05-08-2011 10:14 AM
Dryer is very slow is drying cass19 Washer Repair 1 01-05-2010 01:19 PM
Electric oven slow to heat Fairbob Oven Repair (including Ranges and Cooktops) 5 09-25-2008 08:38 AM
Dryer Dries To Slow Javier Dryer Repair 2 08-21-2007 06:35 PM
