Discuss
Admiral Dryer Timer
 in
Dryer Repair
Dryer won't start ... turned timer to setting and NOTHING happened. Tried several settings and it did not go on.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Admiral Dryer Timer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-03-2008, 05:42 PM
Lyle Lyle is offline
Junior Member
Lyle is on a distinguished road
Default Admiral Dryer Timer
Model Number: ADE7005AYW   Brand: Admiral   Age: 1 - 5 years
Dryer won't start ... turned timer to setting and NOTHING happened. Tried several settings and it did not go on. Timer does not advance when put on any setting.
Light still goes on in the dryer ... so it's getting electricity.
Where can I locate a parts order book to purchase and replace timer?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-03-2008, 07:33 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
Do Not Jump To Conclusions! Check Door Switch. Check For 240 Volts To Dryer. Check For Broken Belt, Check Thermal Fuse If There Is One.
__________________
  #3 (permalink)
Old 05-10-2008, 12:43 PM
Junior Member
Default
Timer was not it. Do I have to take back off to check belt? How do I know if there is a thermal fuse?
  #4 (permalink)
Old 05-10-2008, 05:45 PM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Before you start buying more parts you first
need to check the source voltage going to the
dryer. Do you have and know how to use a multimeter?
  #5 (permalink)
Old 05-10-2008, 07:22 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default the fuse mounts on the side of the heater
the same screw that holds the heater element holds the fuse. It has 2 white wires going to itmaytag fuse kit.jpgand the kit comes with 2 fuses lucky you. The dryer will not run at all if this fuse is blown because it is in series with the doors switch. What does that mean? The door switch kills power to the dryer when open. So to kill power to the dryer quickly they wired that fuse on the same circuit as that door switch. Clever ain't it?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
admiral dryer tomtom45 Dryer Repair 0 03-13-2008 07:07 PM
admiral dryer kojo Dryer Repair 2 03-13-2008 12:26 PM
Admiral Dryer Dead jeffh Dryer Repair 5 01-24-2008 03:12 PM
Admiral Dryer no power to light or dryer Do-right Dryer Repair 1 01-14-2008 01:15 PM
Dead Admiral Dryer jwboone1981 Dryer Repair 1 01-01-2008 01:59 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
