Discuss
Whirlpool Dryer won't start
 in
Dryer Repair
I have replaced the motor, timer, start switch, heat element, and thermostats, and the dryer still will not start. I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer won't start
  #1 (permalink)
Old 08-27-2007, 09:20 PM
Conrad79 Conrad79 is offline
Junior Member
Conrad79 is on a distinguished road
Question Whirlpool Dryer won't start
Model Number: LER7646EQ1   Brand: Whirlpool   Age: 5 - 10 years
I have replaced the motor, timer, start switch, heat element, and thermostats, and the dryer still will not start. I haven't replaced the door latch because the light comes on when you open the door and the timer goes off. So, what else could it be?
Related Models
Whirlpool LER7646EQ1
Whirlpool LER7646EQ2
Whirlpool LER7646EZ0
Whirlpool LER7646EZ1
Whirlpool LER7646EZ2
Whirlpool LER7646JQ0
Whirlpool LER7646JT0
Whirlpool LER7648KQ0
Whirlpool LER7648KQ1
Whirlpool LER7648KQ2
Whirlpool LER7648KQ3 29"electric Dryer
Whirlpool LER7648KT0
Whirlpool LER7648KT1
Whirlpool LER7648KT2
Whirlpool LER7648KT3 29"electric Dryer
Whirlpool LER7648PQ0 29" Electric Dryer
Whirlpool LER7648PQ1 29" Electric Dryer
Whirlpool LER7648PT0 29" Electric Dryer
Whirlpool LER7648PT1 29" Electric Dryer
Whirlpool LER7848DQ0
Whirlpool LER7848DQ1
Whirlpool LER7848DZ0
Whirlpool LER7848DZ1
Whirlpool LER7858AN0
Whirlpool LER7858AN1
Whirlpool LER7858AN2
Whirlpool LER7858AW0
Whirlpool LER7858AW1
Whirlpool LER7858AW2
Whirlpool LER8620PG0 29"electric Dryer
Whirlpool LER8620PG1 29"electric Dryer
Whirlpool LER8620PW0 29"electric Dryer
Whirlpool LER8620PW1 29"electric Dryer
Whirlpool LER8648LG0
Whirlpool LER8648LG1 29"electric Dryer
Whirlpool LER8648LQ0
Whirlpool LER8648LW0
Whirlpool LER8648LW1 29"electric Dryer
Whirlpool LER8648PG0 29"electric Dryer
Whirlpool LER8648PG1 29"electric Dryer
Whirlpool LER8648PQ0 29" Electric Dryer
Whirlpool LER8648PQ1 29"electric Dryer
Whirlpool LER8648PW0 29"electric Dryer
Whirlpool LER8648PW1 29"electric Dryer
Whirlpool LER8857EQ0
Whirlpool LER8857EQ1
Whirlpool LER8857EQ2
Whirlpool LER8857EZ0
Whirlpool LER8857EZ1
Whirlpool LER8857EZ2
Whirlpool LER8858DQ0
Whirlpool LER8858DQ1
Whirlpool LER8858DZ0
Whirlpool LER8858DZ1
Whirlpool LER8858EQ0
Whirlpool LER8858EQ1
Whirlpool LER8858EQ2
Whirlpool LER8858EZ0
Whirlpool LER8858EZ1
Whirlpool LER8858EZ2
Amana LES10AW Washer - Top Loading
Amana LES19AW Dryer - Gas
Amana LES33AW Dryer - Gas
Amana LES34AW Washer - Top Loading
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Amana LET-480 Range - S/c S/i Ddraft Gas
Amana LET-480A Range - S/c S/i Ddraft Gas
Amana LET-480B Range - S/c S/i Ddraft Gas
Amana LET-480C Range - S/c S/i Ddraft Gas
Whirlpool LET5434AN0
Whirlpool LET5434AQ0
Whirlpool LET5434AW0
Whirlpool LET5436AN0
Whirlpool LET5436AW0
Whirlpool LET5624BN0
Whirlpool LET5624BN1
Whirlpool LET5624BN2
Whirlpool LET5624BQ0
Whirlpool LET5624BQ1
Whirlpool LET5624BQ2
Whirlpool LET5624BW0
Whirlpool LET5624BW1
Whirlpool LET5624BW2
Whirlpool LET5624DQ0
Whirlpool LET5624DQ1
Whirlpool LET6634AN0
Whirlpool LET6634AN1
Whirlpool LET6634AN2
Whirlpool LET6634AQ0
Whirlpool LET6634AQ1
Whirlpool LET6634AQ2
Whirlpool LET6634AW0
Whirlpool LET6634AW1
Whirlpool LET6634AW2
Whirlpool LET6634DQ0
Whirlpool LET6634DQ1
Whirlpool LET6634DZ0
Whirlpool LET6634DZ1
Whirlpool LET6638AN0
Whirlpool LET6638AN1
Whirlpool LET6638AN2
Whirlpool LET6638AQ2
Whirlpool LET6638AW0
Whirlpool LET6638AW1
Whirlpool LET6638AW2
Whirlpool LET6638DQ0
Whirlpool LET6638DQ1
Whirlpool LET6638DZ0
Whirlpool LET6638DZ1
Whirlpool LET7646AN0
Whirlpool LET7646AQ0
Whirlpool LET7646AQ1
Whirlpool LET7646AQ2
Whirlpool LET7646AW0
Whirlpool LET7646AZ0
Whirlpool LET7646AZ1
Whirlpool LET7646AZ2
Whirlpool LET7646DQ0
Whirlpool LET7646DQ1
  #2 (permalink)
Old 08-28-2007, 06:03 AM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Have you check to see if you have the correct voltage going to the dryer?
This video will show you more.
Video: How to check voltage at cord on a Whirlpool electric dryer.
__________________
John Pahl
ApplianceJunk.com
ApplianceDigest.com
  #3 (permalink)
Old 08-29-2007, 04:12 PM
Junior Member
Default Dryer Won't Start
Yes, I checked the voltage, but still no start. It was working fine, then I woke up the other morning and it would'nt do anything.
  #4 (permalink)
Old 10-30-2007, 08:54 AM
1000hills 1000hills is offline
Junior Member
1000hills is on a distinguished road
Default
There is a fuse on the back of the dryer (mine was white) that could be bad. It is located on the tube for the lint trap at the bottom. Mine did the same thing that yours is doing and I replaced it and everything is fine now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer wont start phyllis Dryer Repair 5 10-21-2008 03:24 PM
Dryer start stop JBoyd Dryer Repair 2 12-19-2007 11:38 AM
Dryer start button Yorba Dryer Repair 1 08-13-2007 06:13 PM
Dryer stops running after letting off the Start button Andy Dryer Repair 10 08-01-2007 10:56 PM
Dryer motor is noisey and sometimes humms and doesn't start Tudeman Dryer Repair 2 07-20-2007 04:20 PM
