musicme1
#1 Posted : Monday, February 8, 2010 9:39:12 AM(UTC)
musicme1
My admiral dryer wont heat anymore after we had a power outage. Interior light won't come on.... only after cycle will light switch on. But the motor/drum all work just fine. What needs to be replaced.
Phil
Admiral
ade700ayw
asbout 3 yrs old
#2 Posted : Monday, February 8, 2010 9:06:28 PM(UTC)
Here are your parts includes a wiring diagram
Replacement parts for ADMIRAL ADE7005AYW Dryer - Ele | AppliancePartsPros.com
Sounds like you have lost half the line (L2) as they use this to power the interior light.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
