Discuss
Motor Will Not Start Tub Without Assistance
 in
Dryer Repair
I replaced the motor from Appliance Parts Pros. but the tub still will not start without manual assistance. The start
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Motor Will Not Start Tub Without Assistance
  #1 (permalink)
Old 04-30-2008, 03:15 PM
Junior Member
willm is on a distinguished road
Default Motor Will Not Start Tub Without Assistance
Model Number: LER4634EZ2   Brand: Whirlpool   Age: 5 - 10 years
I replaced the motor from Appliance Parts Pros. but the tub still will not start without manual assistance. The start switch has to be held down for a long time before the motor completly ingages. Is there a problem with a relay in the start switch? When the motor does ingage there is a overload on the cookstove indicating that the dryer is tring to pull additional power. All of this still sounds like a motor problem. HELP!!!!
Ads By Google
Related Models
Whirlpool LER4634EZ2
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
  #2 (permalink)
Old 04-30-2008, 07:15 PM
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
are you saying your stove +dryer are on the same circuit? i hope not!
__________________
  #3 (permalink)
Old 05-01-2008, 05:44 AM
Junior Member
Default
The dryer is on a 30 amp breaker and the stove is on a 50 amp breaker that are next to each other in the breaker box. I have been told that the dryer is trying to draw additional amps when this happens. Is there a relay in the starter switch? Thanks,
  #4 (permalink)
Old 05-01-2008, 06:22 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Either the motor blower is binding in the housing, or the motor is getting reduced voltage. It also is possible you have a burnt wire in the outlet box where the dryer pigtail plugs in, just check.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Motor does not start VICENDA Dryer Repair 0 12-03-2009 08:05 AM
Repair Assistance connieinrivamd Washer Repair 3 09-20-2009 06:13 PM
Assistance in Disasssembling Ice Maker Auger pprotopapa Refrigerator & Freezer Repair 2 07-26-2009 09:33 AM
Washer Repair Assistance Needed Kaizen0468 Washer Repair 1 10-09-2008 10:10 AM
