Discuss
How to replace a heating element?
 in
Dryer Repair
The dryer runs but no heat!!: Ads By Google Related Models Maytag  77C  Dryer - Gas Magic Chef  77E-5CXWM9  Walloven
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How to replace a heating element?
  #1 (permalink)
Old 08-27-2007, 10:58 AM
Junior Member
bjordan2@msn.com is on a distinguished road
Talking How to replace a heating element?
Model Number: 776471   Brand: Admiral   Age: 1 - 5 years
Ads By Google
Related Models
Magic Chef 77E-5CXWM9 Walloven - S/c Mwave Ele
Magic Chef 77E-5EXWW Walloven - S/c Ele
Magic Chef 77EN-5CXWM9 Walloven - S/c Mwave Ele
Magic Chef 77EN-5EXWW Walloven - S/c Ele
Magic Chef 77F-5EVWM
Magic Chef 77F-5EVWW
Magic Chef 77F-5EXWM
Magic Chef 77F-5EXWM9
Magic Chef 77F-5EXWW
Magic Chef 77FA-5EVWM
Magic Chef 77FA-5EVWW
Magic Chef 77FA-5EXWM
Magic Chef 77FA-5EXWW
Magic Chef 77FK-5EVWM
Magic Chef 77FK-5EVWW
Magic Chef 77FK-5EXWM Walloven - S/c Mwave Ele
Magic Chef 77FK-5EXWW Walloven - S/c Ele
Magic Chef 77FN-5EVWM Walloven - S/c Mwave Ele
Magic Chef 77FN-5EVWW Walloven - S/c Ele
Magic Chef 77FN-5EXWM
Magic Chef 77FN-5EXWM9 Walloven - S/c Mwave Ele
Magic Chef 77FN-5EXWW
Magic Chef 77J-5EXWM
Magic Chef 77JK-5EXWM Walloven - S/c Mwave Ele
Magic Chef 77JN-5EVWM Walloven - S/c Mwave Ele
Magic Chef 7858XRA Walloven - S/c Dbl Oven Ele
Magic Chef 7858XRW Walloven - S/c Dbl Oven Ele
Magic Chef 7858XUA Walloven - S/c Dbl Oven Ele
Magic Chef 7858XUW Walloven - S/c Dbl Oven Ele
Magic Chef 7858XVA Walloven - S/c Dbl Oven Ele
Magic Chef 7858XVW Walloven - S/c Dbl Oven Ele
Frigidaire 787 FRIGIDAIRE DISHWASHER 24"
Magic Chef 7898VAD Range - S/c Mwave Ele
Magic Chef 7898VAV Range - S/c Mwave Ele
Magic Chef 7898VRA Range - S/c Mwave Ele
Magic Chef 7898VRV Range - S/c Mwave Ele
Magic Chef 7898VVV Range - S/c Mwave Ele
Magic Chef 7898XRA Range - S/c Mwave Ele
Magic Chef 7898XRW Range - S/c Mwave Ele
Magic Chef 7898XVA Range - S/c Mwave Ele
Kenmore 790.1  HAIR CLIPPERS
Kenmore 790.2  HAIR CLIPPERS
Kenmore 790.3  HAIR CLIPPERS
Kenmore 790.330020  GAS COOKTOP
Kenmore 790.33002990  GAS COOKTOP
Kenmore 790.33002991  GAS COOKTOP
Kenmore 790.330030  GAS COOKTOP
Kenmore 790.33003990  GAS COOKTOP
Kenmore 790.33003991  GAS COOKTOP
Kenmore 790.330040  GAS COOKTOP
Kenmore 790.33004990  GAS COOKTOP
Kenmore 790.33004991  GAS COOKTOP
Kenmore 790.330090  GAS COOKTOP
Kenmore 790.33009990  GAS COOKTOP
Kenmore 790.33009991  GAS COOKTOP
Kenmore 790.330120  GAS COOKTOP
Kenmore 790.33012990  GAS COOKTOP
Kenmore 790.33012991  GAS COOKTOP
Kenmore 790.330130  GAS COOKTOP
Kenmore 790.33013990  GAS COOKTOP
Kenmore 790.33013991  GAS COOKTOP
Kenmore 790.330140  GAS COOKTOP
Kenmore 790.33014990  GAS COOKTOP
Kenmore 790.33014991  GAS COOKTOP
Kenmore 790.330190  GAS COOKTOP
Kenmore 790.33019990  GAS COOKTOP
Kenmore 790.33019991  GAS COOKTOP
Kenmore 790.33022100  GAS COOKTOP
Kenmore 790.33023100  GAS COOKTOP
Kenmore 790.33024100  GAS COOKTOP
Kenmore 790.33029100  GAS COOKTOP
Kenmore 790.33032100  GAS COOKTOP
Kenmore 790.33033100  GAS COOKTOP
Kenmore 790.33034100  GAS COOKTOP
Kenmore 790.33039100  GAS COOKTOP
Kenmore 790.45702300  GAS RANGE
Kenmore 790.45704300  GAS RANGE
Kenmore 790.45709300  GAS RANGE
Kenmore 790.45712100  DUAL FUEL SIDE-IN RANGE
Kenmore 790.45712102  SEARS/GAS RANGE
Kenmore 790.45712103  SEARS/GAS RANGE
Kenmore 790.45714100  DUAL FUEL SIDE-IN RANGE
Kenmore 790.45714102  SEARS/GAS RANGE
Kenmore 790.45714103  SEARS/GAS RANGE
Kenmore 790.45719100  DUAL FUEL SIDE-IN RANGE
Kenmore 790.45719102  SEARS/GAS RANGE
Kenmore 790.45719103  SEARS/GAS RANGE
Kenmore 790.46132300  GAS RANGE
Kenmore 790.46133300  GAS RANGE
Kenmore 790.46134300  GAS RANGE
Kenmore 790.46139300  GAS RANGE
Kenmore 790.468120  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812991  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468130  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813991  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468140  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468190  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46832100  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46832101  SEARS/GAS RANGE
Kenmore 790.46832102  SEARS/GAS RANGE
Kenmore 790.46833100  DUAL FUEL RANGE
Kenmore 790.46833101  SEARS/GAS RANGE
Kenmore 790.46833102  SEARS/GAS RANGE
Kenmore 790.46834100  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46834101  SEARS/GAS RANGE
Kenmore 790.46834102  SEARS/GAS RANGE
Kenmore 790.46839100  DUAL FUEL SLIDE-IN RANGE
Last edited by bjordan2@msn.com : 09-05-2007 at 04:11 PM. Reason: Heating element and fuses tested good. What else can I try?
  #2 (permalink)
Old 08-28-2007, 10:00 AM
Admin / APP Team's Avatar
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
First, I would make sure this dryer is getting 220 volts. Check the circuit breaker, check the wall socket, check the terminal block inside the dryer. Then, I'd check the heating element, thermistor and thermal fuse for continuity with an ohmmeter. Do not assume the heating element is bad just because it's not turning on.
  #3 (permalink)
Old 09-05-2007, 04:15 PM
Junior Member
Default
The heater element and fuses was tested and are good, what can I try next?
  #4 (permalink)
Old 09-12-2007, 05:56 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
If your dryer has a element just below the lid, check the overload thermostat above it, common failure item. If ok check the timer contacts per the schematic.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how to replace heating element jaydence Dryer Repair 3 12-21-2009 04:26 PM
replace heating element palmera Dryer Repair 1 11-21-2009 05:18 PM
When to replace a heating element? starkey5 Dishwasher Repair 0 10-09-2009 04:56 PM
Replace Heating Element Stunt Double Dishwasher Repair 0 07-28-2008 05:40 PM
Need to replace heating element Nova Dryer Repair 0 01-05-2008 12:39 AM
