Discuss
keeps shutting off
 in
Dryer Repair
My dryer keeps shutting off during the cycle. I have replaced the thermostat near the motor and also the one
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » keeps shutting off
  #1 (permalink)
Old 02-06-2010, 06:31 AM
Junior Member
marie hornung is on a distinguished road
Default keeps shutting off
Model Number: LNC7764A71   Brand: Admiral   Age: 5 - 10 years
My dryer keeps shutting off during the cycle. I have replaced the thermostat near the motor and also the one that controls the light. There is one more to replace, but I am reluctant to spend any more money and have it not work. It runs sometimes for 10 minutes, and other times it completes the cycle. I have cleaned out all the lint and checked to see that the air vent is not clogged. It seems like it is a temperature control problem. I took it apart, drum and all, and don't see anything suspect.
Ads By Google
Related Models
Admiral LNC7764A71 Dryer - Ele
Admiral LNC7764A77 Dryer - Ele
Admiral LNC7766A00 Dryer - Ele
International LNC7766A00 Dryer - Ele
Admiral LNC7766A71 Dryer - Ele
International LNC7766A71 Dryer - Ele
Admiral LNC7766B71 Dryer - Ele
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
  #2 (permalink)
Old 02-06-2010, 07:26 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for ADMIRAL LNC7764A71 Dryer - Ele | AppliancePartsPros.com
Not sure what you mean by this, as far as I know there is not a thermostat that controls the light.
I am assuming that you cleaned the motor and also cleaned/checked the blower wheel.
Can you restart it right away or do you have to wait several minutes before it will restart?
Do you have to do anything else to get it to start re: open/close the door etc.?
If you have to wait it is usually the motor that is overheating and tripping it's internal thermal protect.
Try rotating the drum in the correct direction by hand, should rotate fairly easily. You may want to try this on a couple other driers, just to get a feel for it.
Could be the drum is overloading the motor.
Often it is just the motor is getting close to the end of it's lifetime.
__________________
  #3 (permalink)
Old 02-14-2010, 04:02 AM
Junior Member
Default no heat
My dryer kept shutting off during the cycle. I suspected the thermostat but was afraid to buy anymore parts. Now, the drum turns, the heater coil is intact, but no heat. Is this an indication that the thermostat near the heat element is bad? Could this be why my dryer kept shutting off?
  #4 (permalink)
Old 02-14-2010, 04:37 AM
Junior Member
badbackguy is on a distinguished road
Default
Try this video on troubleshooting your dryer.
service manuals
  #5 (permalink)
Old 02-14-2010, 05:55 AM
Junior Member
Default
Quote:
service manuals
I have an ohm meter, but don't know how to use it. I have tried what he is showing me in the video, but don't get the needle to move. The meter works if I put it in a wall socket, but I can't get it to move when I test it on the thermostat wires. What am I doing wrong?
  #6 (permalink)
Old 02-14-2010, 02:46 PM
Senior Expert
APP Volunteer
Default
Do not know what video you watched but to measure for continuity.
Put the meter to ohms/resistance.
Then short the meter leads together the meter should move to 0 ohms.
Note a thermostat will not cause the motor to shut off, all they control is the heating coil.
__________________
  #7 (permalink)
Old 02-15-2010, 07:02 AM
Junior Member
Default
what would cause the motor to keep starting and stopping? It has been going on for months. Is the motor dying?
  #8 (permalink)
Old 02-15-2010, 10:17 AM
Senior Expert
APP Volunteer
Default
Is the motor dying?
Yes; it could be.
Try turning the drum in the correct direction, it should turn fairly easily.
If not perhaps the drum is dragging and putting too much load on the motor.
You may want to try this on a couple other dryers just to get a feel for it.
Also check that the motor is free of dust/lint. Could be it is clogged solid with lint and is not cooling properly.
__________________
  #9 (permalink)
Old 02-22-2010, 04:35 PM
Junior Member
I decided to try something new. I put the clothes in the dryer and it shut off after about 5 - 7 minutes. I waited a while and put them in on "air fluff" only. It didn't shut off after 20 minutes. I then put the temperature on "delicate" and it did not shut off after about 20 minutes. I then turned the temperature dial to "regular" heat, and it shut off in about 5 minutes. What does this tell you?
I just can't let it go. This dryer will not win.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
keeps shutting off marie hornung Dryer Repair 5 02-26-2010 01:35 PM
Fridge shutting off tomok Refrigerator & Freezer Repair 11 05-05-2009 04:38 PM
GE Refrigerator keeps shutting off. cyberunlimited Refrigerator & Freezer Repair 1 04-13-2009 09:26 PM
Microwave Fan Not Shutting off fivestar Microwave Repair 1 03-02-2009 05:46 PM
Oven Keeps Shutting off bwintrow@hotmail.com Oven Repair (including Ranges and Cooktops) 1 03-02-2009 05:11 PM
