Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   keeps shutting off (http://forum.appliancepartspros.com/dryer-repair/76019-keeps-shutting-off.html)
marie hornung 02-06-2010 06:31 AM
keeps shutting off
My dryer keeps shutting off during the cycle. I have replaced the thermostat near the motor and also the one that controls the light. There is one more to replace, but I am reluctant to spend any more money and have it not work. It runs sometimes for 10 minutes, and other times it completes the cycle. I have cleaned out all the lint and checked to see that the air vent is not clogged. It seems like it is a temperature control problem. I took it apart, drum and all, and don't see anything suspect.
denman 02-06-2010 07:26 AM
Replacement parts for ADMIRAL LNC7764A71 Dryer - Ele | AppliancePartsPros.com
Not sure what you mean by this, as far as I know there is not a thermostat that controls the light.
I am assuming that you cleaned the motor and also cleaned/checked the blower wheel.
Can you restart it right away or do you have to wait several minutes before it will restart?
Do you have to do anything else to get it to start re: open/close the door etc.?
If you have to wait it is usually the motor that is overheating and tripping it's internal thermal protect.
Try rotating the drum in the correct direction by hand, should rotate fairly easily. You may want to try this on a couple other driers, just to get a feel for it.
Could be the drum is overloading the motor.
Often it is just the motor is getting close to the end of it's lifetime.
marie hornung 02-14-2010 04:02 AM
no heat
My dryer kept shutting off during the cycle. I suspected the thermostat but was afraid to buy anymore parts. Now, the drum turns, the heater coil is intact, but no heat. Is this an indication that the thermostat near the heat element is bad? Could this be why my dryer kept shutting off?
badbackguy 02-14-2010 04:37 AM
Try this video on troubleshooting your dryer.
service manuals
marie hornung 02-14-2010 05:55 AM
Quote:
service manuals
I have an ohm meter, but don't know how to use it. I have tried what he is showing me in the video, but don't get the needle to move. The meter works if I put it in a wall socket, but I can't get it to move when I test it on the thermostat wires. What am I doing wrong?
denman 02-14-2010 02:46 PM
Do not know what video you watched but to measure for continuity.
Put the meter to ohms/resistance.
Then short the meter leads together the meter should move to 0 ohms.
Note a thermostat will not cause the motor to shut off, all they control is the heating coil.
marie hornung 02-15-2010 07:02 AM
what would cause the motor to keep starting and stopping? It has been going on for months. Is the motor dying?
denman 02-15-2010 10:17 AM
Is the motor dying?
Yes; it could be.
Try turning the drum in the correct direction, it should turn fairly easily.
If not perhaps the drum is dragging and putting too much load on the motor.
You may want to try this on a couple other dryers just to get a feel for it.
Also check that the motor is free of dust/lint. Could be it is clogged solid with lint and is not cooling properly.
marie hornung 02-22-2010 04:35 PM
keeps shutting off
I decided to try something new. I put the clothes in the dryer and it shut off after about 5 - 7 minutes. I waited a while and put them in on "air fluff" only. It didn't shut off after 20 minutes. I then put the temperature on "delicate" and it did not shut off after about 20 minutes. I then turned the temperature dial to "regular" heat, and it shut off in about 5 minutes. What does this tell you?
I just can't let it go. This dryer will not win.
