Discuss
Frigidaire Dryer that won't heat
 in
Dryer Repair
My dryer is still blowing air but it's cold air only... What could be wrong with it?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire Dryer that won't heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-28-2008, 04:37 PM
huha69 huha69 is offline
Junior Member
huha69 is on a distinguished road
Exclamation Frigidaire Dryer that won't heat
Model Number: CER3600AS1   Brand: Frigidaire   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-28-2008, 07:23 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
heater .thermostats, timer. or not getting 220 volts to dryer
__________________
  #3 (permalink)
Old 05-07-2008, 04:56 PM
Drea Drea is offline
Junior Member
Drea is on a distinguished road
Default
Quote:
Isn't that answer too vague? I have the same problem...but I am thinking it is the igniter. We used to hear a metal scraping sound shortly before you would hear a click and the gas ignite....now we just hear the metal scraping and never hear the click....and in turn...no gas igniting...the dryer will just run and not heat. Blowing cold air would indicate that 220 volts is reaching the dryer...Senior Expert.
  #4 (permalink)
Old 05-08-2008, 05:50 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default if this is a gas dryer which looking it up says it is eletwic
The way it works is: The ignitor comes on. The coils are on the same circuit. But they will not open. why? because the glowbar/ignitor is robing them of the current needed to open the valve. Clever ain't it. So how does the coils get the voltage needed to open the gas gates and let the glorios sound of hotness come belching out? Simple: The flame sensor is also in the same circuit. They are all one big family, all on the same little electrical circuit. The glowbar/ignotor is robbing all the current remeber. It gets hotter and hotter and hotter, till that flame sensing box mount on the outside by the ignitor just cannot stand it no more. It Kills power going to that glowbar/ignitor and a spike of electricity all of a sudden energises them coil and whoosh the raw gas comes a pouring out onto that cherry red glowthing and Kaboom that gas get lit. It stay lit too until the drum temperature sensing klixon is happy. then that klixon kills power to the gas valve/ignitor/flame sensor. The gas shuts down and the dryer keeps on a trucking along. Just all warm and happy. till that drum temperature just a bit cool. then that klixon says to itself,self? is it a bit chilly in here right now? Lets fire up that gas valve assembly and get a little heat going on up in here. This process repeats itself all through the drying cycle till the clothes are dry.
  #5 (permalink)
Old 05-08-2008, 06:03 PM
Senior Expert
APP Volunteer
Default So what can go wrong?
The glowbar can fail and mess up the whole works. Or the high limit will kick out due to venting problemas. The flame sensora flame sensor 2.bmp if it is open will not allow for the glowbar to fire up thus no heat lets see what else. oh yeah the controling thermostat mounted near the vent blower will die and that will not allow for power to get to the gas valve assembly. If it work some and then not at all them coils need changing. An old school simple way to check the heater/gasvalve assembly is as follows: Warning this is dangerous but what ain't. What you do is get the wife or a friend to be a witness Oops I mean to assist. remove the 2 wires going to the flame sensor hold them apart and have your friend start the dryer on the heat cycle. touch them 2 wire together and see if that glowbar comes on,wait 5 seconds and seperate the wires. the gas should ignite. if it does then your flame sensor is bad.replace that. If that glowthingy don't light up at all then you are not getting 120 volts to them 2 wire or the ignitor is bad. That ought to be enough to git ye started or killed HaHa Just kidding. LOL Be careful . any question just ask away.
  #6 (permalink)
Old 05-13-2008, 05:31 PM
Junior Member
Default Thank you for the detailed response :)
I'm a liddle bit, confused by the baby talk...but my dryer heats by Gas...wish me luck, that I don't burn all my hair off! Thanks again!
  #7 (permalink)
Old 05-13-2008, 06:22 PM
Senior Expert
APP Volunteer
Default I am a Cajun
Believe it or not I really talk the way I type sometimes. I get in the moment and type what i feel. Bon Chance on your dryer problem mon ami.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Gas Dryer - heat inconsistent futbol79 Dryer Repair 3 04-15-2008 02:23 AM
frigidaire gas dryer has no heat chevyguy Dryer Repair 0 03-01-2008 10:06 PM
Frigidaire Electric Oven Doesn't Heat sharzaz Oven Repair (including Ranges and Cooktops) 7 02-09-2008 04:07 PM
Frigidaire Gas Dryer works but No Heat, Why?? mvetri Dryer Repair 3 11-02-2007 03:46 PM
Frigidaire dryer dennis patton Dryer Repair 1 09-14-2007 10:44 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
