Discuss
ohm meter
 in
Dryer Repair
I would like to check to see if the thermo fuse on my dryer is the problem that needs fixed...
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » ohm meter
  #1 (permalink)
Old 04-28-2008, 03:27 AM
KRO KRO is offline
Junior Member
KRO is on a distinguished road
Default ohm meter
Model Number: LER4634JTO   Brand: Whirlpool   Age: 5 - 10 years
I would like to check to see if the thermo fuse on my dryer is the problem that needs fixed...I have a Sperry ohm meter DM-210A but I'm not quite sure how to use it...does the power have to be on to the dryer?...and how do I set the meter to show me if this is the problem? I've double checked everything 10 times with the dryer...the timer runs, it begins to heat but when I press the on button nothing happens...checked door also and breaker box...thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-28-2008, 05:52 AM
fixtec90 fixtec90 is offline
Senior Expert
APP Volunteer
fixtec90 is on a distinguished road
Default
I can't tell you how to set your meter w/o seeing it, but you can check your t-fuse by:
Unplug dryer
Remove the wires from the t-fuse and jump them together
Make sure wires (now connected) aren't touching anything conductive (metal)
Plug dryer in and start. If the dryer starts, runs, and heats replace t-fuse.
  #3 (permalink)
Old 04-28-2008, 09:28 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
KRO,
In addition to fixrec90, the following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
