Discuss
whirlpool electric dryer
 in
Dryer Repair
I thought I had messed up the timer one day when I spun it 360 degrees while it was running.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool electric dryer
  #1 (permalink)
Old 04-26-2008, 02:10 PM
KRO KRO is offline
Junior Member
KRO is on a distinguished road
Default whirlpool electric dryer
Model Number: LER4634JTO   Brand: Whirlpool   Age: 5 - 10 years
I thought I had messed up the timer one day when I spun it 360 degrees while it was running. I bought a new timer but it still doesnt run...the dryer is making sounds and it heats up but no matter what I've try to do whenever I push the on button its not wanting to spin...the sounds coming from the dryer I believe are from the timer...I dont hear anything that would sound like a motor...kinda fustrating...the timer cost me $100...is there anything else that I look into without guessing and ordering another part I might not need? its been a great appliance for the 6 years we've owned it...just wondering if anyone could enlighten me...thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-26-2008, 05:27 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
If you have house fuse take a look at them first. The dryer would use two of them to make it run and heat.
Another simple thing you could check would be the door switch. Open the door and push the switch in by hand to see if you can hear it click on and off.
There are some thermo fuse in the dryer that will also make it not run if they go bad. You will need a ohm meter to check them.
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool electric dryer won't heat pilzperson Dryer Repair 0 04-03-2008 02:46 PM
Whirlpool Electric Dryer kwillson Dryer Repair 1 03-28-2008 04:30 PM
Whirlpool Electric Dryer mopsgt Dryer Repair 5 03-12-2008 04:59 PM
Whirlpool Electric Dryer--No Heat hnumrich Dryer Repair 0 02-05-2008 07:14 AM
whirlpool electric dryer beefacres Dryer Repair 5 01-03-2008 05:31 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
