This is a GE gas dryer Model DPFS505GW0WW. The Automatic Cycle does not work properly. The Timed Drying works fine. I note in the Owner's Manual it states the "SensorDry" stops the heating cycle when the clothes have reached the selected dryness. I suspect this sensor is the problem as when put on Automatic, the dryer finishes and the clothes are still wet. Is this sensor the problem? Is it worth replacing on a 10 year old dryer? If so, where is it and how do I replace it? JohnM432
