| » Gas dryer still won't heat after new igniter & coils |
Model Number: pyg2000aww Brand: Maytag Age: 5 - 10 years
This dryer runs (drum spins) but never heats up. I just replaced the igniter and 2 coils but no luck. Any suggestions on what I should try next?
Thanks, Carl |
Check flame sensor for continuity (#13 on this diagram), also check the thermal cut-off (looks like a thermostat, less than an inch in diameter).
Doesn't really sound like the same problem, Peg. Click here, then click on the POST NEW TOPIC button and describe your problem in detail. Don't forget to include the model number of your Amana dryer.
The terminal for the white wire on the flame sensor broke off. I had seen the white wire laying there but couldnt figure out where it went and assumed it wasn't being used. Looks like I should try replacing the flame sensor now? I don't see anyway of repairing the broken terminal. Thanks for the guidance, Carl
Quote:
Post edited by admin. Reason: advertising |
| Display Modes | |
| Dryer will run but not heat | allansc | Dryer Repair | 12 | 12-28-2007 07:10 PM |
| Replaced the igniter and there is still no heat in my oven??!! | Ruben | Oven Repair (including Ranges and Cooktops) | 1 | 08-21-2007 11:44 AM |
| Igniter glows but no flame. | zab | Dryer Repair | 1 | 08-06-2007 07:55 PM |
| Dryer won't heat | dwh | Dryer Repair | 1 | 07-30-2007 06:35 PM |
| Removing dryer cabinet to repair igniter | Mikeofba | Dryer Repair | 1 | 07-27-2007 11:48 PM |
