ATR
#1 Posted : Tuesday, February 2, 2010 7:54:58 PM(UTC)
ATR
Dryer Motor Hums And Won't Run,if I Press The Door And Start Switches And Turn The Drum It Will Run.is This The Motor Or The Motor Switch.:(
#2 Posted : Wednesday, February 3, 2010 1:02:59 AM(UTC)
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG LSE7806ACE Stacked Laundry - Ele | AppliancePartsPros.com
Here is a tech bulletin which may apply
http://www.servicematters.com/maytag_library/docs/TDL-0093-B.pdf
Here is a manual, there is info on a SE7800 at the end of it. Cannot say how close a match it will be to yours but it may come in handy. Does look like the wiring is different.
http://www.servicematters.com/maytag_library/docs/16000416.pdf
[COLOR="Blue"]
is This The Motor Or The Motor Switch[/COLOR]
Cannot say as it could be either.
First check that the drum turns manually fairly easily.
Check the motor windings with a meter.
Check that the motor is not clogged solid with lint etc.
Check that the centrifugal mechanism on the motor is not holding the switch closed all the time.
Check the switch with a meter.
Be sure to make yourself a diagram of where the wires attach if removing more than one. You would be surprised at how many times people post here with "where do the wires attach" and sometimes no one can help.
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
Crosley electric dryer door handle part number (Dryer Repair)
by Guest 10/22/2023 1:05:15 PM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Frigidaire model ferb5700ds0 electric dryer (Dryer Repair)
by rnh7133 7/29/2023 6:22:58 AM(UTC)
Maytag electric dryer with coin type operation model MDE16CSAYW (Dryer Repair)
by Guest 6/29/2023 9:53:26 AM(UTC)
Older Speed Queen electric dryer (Dryer Repair)
by Guest 3/29/2023 5:23:19 AM(UTC)
