Discuss
Kenmore Dryer Stopped Working
 in
Dryer Repair
I started a load in the dryer and after a few minutes I nticed it stopped running. There were no
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Dryer Stopped Working
  #1 (permalink)
Old 08-26-2007, 11:18 PM
Rob Rob is offline
Junior Member
Rob is on a distinguished road
Default Kenmore Dryer Stopped Working
Model Number: 110.67832794   Brand: Kenmore   Age: More than 10 years
I started a load in the dryer and after a few minutes I nticed it stopped running. There were no noises or strange sounds it just stopped. I tried to restart it but nothing. I did however notice that if you hold the start button in the timer makes a slight clicking noise. Any ideas
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-02-2007, 08:09 PM
flowmaster2005 flowmaster2005 is offline
Junior Member
flowmaster2005 is on a distinguished road
Default similar problem
I once had a similar problem and it turned out to be a computer board located by the timer that went bad. It's a very simple disconnect-replace-connect process...hope that helps.
  #3 (permalink)
Old 09-06-2007, 11:44 AM
candsray candsray is offline
Junior Member
candsray is on a distinguished road
Angry Sounds familiar
Our Kenmore Dryer 6 yrs old also stopped except light still works. Ruled out power cord, circuit breaker and checked continuity on start switch, door switch and timer - all good but could not get reading on the computer board next to timer and is not shown on parts list. After several calls to Sears parts finally got part number and ordered but they do not stock in Sears parts store and will take almost 2 weeks to arrive. Were also told could not return electronic parts if plugged in. Part is $114.99. Our timer also makes the clicking sound when start button pushed. Husband very frustrated at this point.
  #4 (permalink)
Old 09-16-2007, 06:00 AM
weity weity is offline
Junior Member
weity is on a distinguished road
Default
my belt broke on my kennmore dryer i replaced that and the door swith! My dryers old.I have no heat in the drum now!!The heating element glows big time! Could it be the sensor? It says to use a ohm meter set at r 10 ..It should read zero ..Any ideas ??what sensor would i look at the one on the heating element side or the vent side?
  #5 (permalink)
Old 09-19-2007, 08:23 PM
andrewlettington andrewlettington is offline
Junior Member
andrewlettington is on a distinguished road
Default
maybe the squirrel cage fan has stripped out on the drive shaft.you'll still get heat but no fan drawing the heat through the drum. sooner or later the thermostat over the heater element will blow as it will get too hot as a result of no cool air being drawn in over the heater element and too much hot air buildup behind the drum
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker Stopped Working banluc Refrigerator & Freezer Repair 2 09-25-2007 07:28 PM
Ice Maker Stopped working Judymike08@yahoo.com Refrigerator & Freezer Repair 1 08-26-2007 08:56 AM
Kenmore dryer jdman Dryer Repair 3 08-04-2007 08:53 PM
Kenmore dryer will not run appbaffled Dryer Repair 2 07-23-2007 07:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
