Discuss
Whirlpool dryer - no heat
 in
Dryer Repair
verruckt, If the thermal fuse (#8 on the break down diagram) is open - it has to be replaced. If the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool dryer - no heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #11 (permalink)
Old 05-05-2008, 03:36 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
verruckt,
If the thermal fuse (#8 on the break down diagram) is open - it has to be replaced. If the part you mentioned is not the thermal fuse then try to locate it on the break down diagram and post the reference number.
- The part number for the thermal fuse is AP3133489
Here are the break down diagrams for the Whirlpool dryer Model LE5800XMW1
__________________
Professional appliance repair services in Orange County, California.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 05-05-2008, 07:05 PM
verruckt verruckt is offline
Junior Member
verruckt is on a distinguished road
Default
Actually what I 'thought' was the fuse, was #5 here
Model LE5800XMW1
At the parts store they told me it wasn't the fuse. So they sold me the one you suggested and went back home. However, I have tested my thermal fuse, and it was good. I also tested what appears to be three thermostats on the same housing as the thermal fuse, they all tested good for continuity. They look exactly like the high limit thermostat on my heat element housing.
  #13 (permalink)
Old 05-10-2008, 08:40 AM
Junior Member
Default
Ok, this is REALLY starting to suck.
I started over from the very beginning and followed everything, from power source to the heating element. This time, the hi limit thermostat tested bad. In the beginning, it tested good. I've replaced it before, so I know what it is and how to test it. One of the leads was loose, and a little burnt looking which i didnt see the first time. If you wiggled the lead, it would test good, if it was moved slightly it would test bad. So, i replaced it. Plugged in the dryer and started it up. It immediately threw the breaker. My breaker is a double, so it threw the whole thing.
  #14 (permalink)
Old 05-10-2008, 09:14 AM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
check to see if any of your wires are are toucing another wire or touching body of dryer .are all your wires at correct connections
__________________
  #15 (permalink)
Old 05-10-2008, 09:39 AM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Also disconnect the heating element,
Then check the resistance of the element, it should be
somewhere around 8-12 ohms.
Then check to make sure that there is “no continuity”
between ether terminal and case ground
If there is then the element is shorted.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool gas dryer will not heat. brae Dryer Repair 2 04-24-2008 07:21 AM
Whirlpool Gas Dryer runs but won't heat Annamarie Dryer Repair 1 11-12-2007 03:46 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
Whirlpool gas dryer runs but no heat c1gia Dryer Repair 0 08-14-2007 08:26 PM
Whirlpool Dryer - No heat Warren Dryer Repair 0 08-14-2007 03:30 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
