Discuss
Admiral Electric Won't Start - replaced parts... read
 in
Dryer Repair
Hello everyone.. new here. I have an Admiral ADE7005AYW Electric Dryer The dryer was working fine, went to start another
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Admiral Electric Won't Start - replaced parts... read
  #1 (permalink)
Old 04-22-2008, 03:55 PM
Junior Member
sixthsphere is on a distinguished road
Default Admiral Electric Won't Start - replaced parts... read
Model Number: ADE7005AYW   Brand: Admiral   Age: 1 - 5 years
The dryer was working fine, went to start another load, pushed start button... nothing...
I did some google searching and found many people's problems with this dryer was the thermal fuse, or thermostat.
I had both parts overnighted
I just replaced the Thermal Fuse and Thermostat about an hour ago
Plugged my dryer back in, pushed the start button and nothing... no relay clicks, no sounds... and most annoying of all... no dry clothes
I also noticed the light inside the door is now out, whereas before it was working...
Did I blow out some other fuse inside my dryer? Anyone know what to check next?
The 220 line is fine, circuit breakers are not popped.
Please help... I thought my Laundromat days were over
Ads By Google
Related Models
Admiral ADE7005AYW Dryer - Ele
Maytag ADE808 Dryer - Ele
Admiral ADE9000AYW Dryer - Ele
Admiral ADE9005AGW Dryer - Ele
Whirlpool ADF07520
Whirlpool ADF07521
Whirlpool ADF07522
Whirlpool ADF10020
Whirlpool ADF10220
Whirlpool ADF11021
Whirlpool ADF12020
Whirlpool ADF12540
Whirlpool ADF13520
Whirlpool ADF13521
Whirlpool ADF13522
Whirlpool ADF13523
Whirlpool ADF17040
Whirlpool ADF18040
Whirlpool ADF18041
Whirlpool ADF18043
Whirlpool ADF18044
Whirlpool ADF18240
Whirlpool ADF21240
Whirlpool ADF21340
Whirlpool ADF21342
Whirlpool ADF21343
Whirlpool ADF29040
Whirlpool ADF29041
Whirlpool ADF29042
Whirlpool ADF29043
Whirlpool ADFC6320
Whirlpool ADFC6321
Whirlpool ADFC6322
Whirlpool ADFE1240
Whirlpool ADFE1241
Whirlpool ADFE1242
Whirlpool ADFE1540
Whirlpool ADFE1541
Whirlpool ADFE1542
Whirlpool ADFE1830
Whirlpool ADFE1831
Whirlpool ADFH0720
Whirlpool ADFH0721
Whirlpool ADFH2130
Whirlpool ADFP5020
Whirlpool ADFP5021
Whirlpool ADFP5022
Whirlpool ADFP5023
Whirlpool ADFP5520
Whirlpool ADFP6021
Whirlpool ADFP6022
Whirlpool ADFP8020
Whirlpool ADFP8021
Whirlpool ADFR1240
Whirlpool ADFS1020
Whirlpool ADFS1021
Whirlpool ADFS6020
Whirlpool ADFS6021
Whirlpool ADFS8020
Whirlpool ADFS8021
Whirlpool ADFS8022
Whirlpool ADFW0940
Whirlpool ADFW0941
Whirlpool ADFW0942
Whirlpool ADFW1240
Whirlpool ADFW1241
Whirlpool ADFW1242
Whirlpool ADFW1540
Whirlpool ADFW1541
Whirlpool ADFW1542
Whirlpool ADFW1543
Whirlpool ADFW1544
Maytag ADG107 Dryer - Gas
Admiral ADG20K2A Dryer - Gas
Admiral ADG20K2H Dryer - Gas
Admiral ADG20K2W Dryer - Gas
Admiral ADG20K3 Dryer - Gas
Admiral ADG20K3A Dryer - Gas
Admiral ADG20K3H Dryer - Gas
Admiral ADG20K3V Dryer - Gas
Admiral ADG20K3W Dryer - Gas
Admiral ADG20K4 Dryer - Gas
Admiral ADG20K4A Dryer - Gas
Admiral ADG20K4H Dryer - Gas
Admiral ADG20K4W Dryer - Gas
Admiral ADG20L1A Dryer - Gas
Admiral ADG20L1H Dryer - Gas
Admiral ADG20L1W Dryer - Gas
Admiral ADG20L2A Dryer - Gas
Admiral ADG20L2H Dryer - Gas
Admiral ADG20L2W Dryer - Gas
Admiral ADG20L4 Dryer - Gas
Admiral ADG20L4A Dryer - Gas
Admiral ADG20L4H Dryer - Gas
Admiral ADG20L4W Dryer - Gas
Admiral ADG20M3V Dryer - Gas
Admiral ADG20N3V Dryer - Gas
Maytag ADG308 Dryer - Gas
Maytag ADG309 Dryer - Gas
Maytag ADG408 Dryer - Gas
Maytag ADG409 Dryer - Gas
Maytag ADG608 Dryer - Gas
Admiral ADG7000AWW Dryer - Gas
Admiral ADG7005AWW Dryer - Gas
Maytag ADG808 Dryer - Gas
Admiral ADG9000AWW Dryer - Gas
Amana ADGS902E Range - S/c S/i Ddraft Gas
Amana ADGS902SS Range - S/c S/i Ddraft Gas
Amana ADGS902WW Range - S/c S/i Ddraft Gas
General Electric ADH15D3Z1 Room air conditioner
General Electric ADH18D1G1 Room air conditioner
General Electric ADH18D1G2 Room air conditioner
General Electric ADH18D1G3 Room air conditioner
General Electric ADH18D3E1 Room air conditioner
General Electric ADH23D1X1 Room air conditioner
General Electric ADH23D3B1 Room air conditioner
Whirlpool ADJ06020
Whirlpool ADJ07220
Whirlpool ADJ07221
Whirlpool ADJ07520
  #2 (permalink)
Old 04-23-2008, 06:09 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
You sound like you have a bad door switch. If you need me you can reach me at my website at ******************************************** Tom
  #3 (permalink)
Old 04-23-2008, 03:17 PM
Junior Member
Default
last night I popped out the door switch...
there were three wires on it, red connector, no connector and a blue connector...
I ran a jumper wire between the red connector one and the one with no connector... I pushed START and the light lights up until I release the start button.
So i jumped the red connector and blue connector wires, thinking theoretically, the dryer would think the door was closed.
I press start and nothing...
should my dryer have started?
I took apart the door switch and it does look burned out, so I will replace that... but how many more parts should I replace before giving up?
  #4 (permalink)
Old 04-23-2008, 06:00 PM
Senior Expert
APP Volunteer
Default
From what you are said you checked the door switch wold be the last thing. Tom ********************************************
  #5 (permalink)
Old 04-23-2008, 07:33 PM
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
You may have jumperd the wrong two wires.
You would need to jumper the white wire to the
yellow one. If it dosent start then you need to do
some further electrical testing on the dryer.
You will need to know how to use a multimeter
in order to do that.
  #6 (permalink)
Old 04-24-2008, 03:20 PM
Junior Member
Default
I say connector, but what I really meant was that the clip dealie on the end of the wire had a plastic "surround" on it to keep it from shorting against the other wires.
One of the surrounds was red plastic (the wire was yellow, had power when START is pressed)
The one that i said had no connector had no "surround" (grey wire, went to light bulb for inside the dryer)
and the Blue "surround" one was on the white wire (which was what i jumped to the Yellow wire to trick the dryer into thinking the door was "closed")
  #7 (permalink)
Old 04-25-2008, 04:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
sixthsphere,
Lets start over, according to the wiring diagram for your dryer.
You must have a simple multitester because we have to check some parts for continuity and for proper voltage. You have to buy one if you do not have it.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
The simple analog multitester
1. There is suppose to be 240V at the power outlet. Check for 120V between any hot outlet and the neutral and check for 240V between both hot outlets. If there is anything wrong - call an electrician.
2. Remove the rear access cover form the dryer and check the terminal block (where the power cord is connected to the dryer) for any burned wires and/or loose connections. If there is anything wrong - fix it.
3. Check the door switch for continuity. With the door closed,the WH(white) and the GY(gray) circuit should be open and the WH(white) and the YL/BK(yellow - black) circuit should be closed. If the readings are wrong - replace the door switch.
4. Remove the wires from the "M" and the "S" terminals on the timer and check for continuity across these terminals while it's pushed to start. If the circuit is open - replace the timer.
- The part number for the door switch is AP4319999
- The part number for the timer is AP3856076
- The part number for the multimeter is AP3549875
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #8 (permalink)
Old 04-25-2008, 05:58 PM
Junior Member
Default
thanks for the advice... i'll look into this
I have already replaced my door switch (today in fact) and when the door is open, no light... something is royally screwed I think.
I'll check that timer tomorrow... but I think I may be out of luck here
I bought the dryer at an auction about a month ago for $65 and have already put another 60 into in parts that I apparently didn't need
makes me sad...
  #9 (permalink)
Old 04-25-2008, 09:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very possible the problem is with the power source.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Oven Heat HELP parts replaced Kenmore Elite KiaTia Oven Repair (including Ranges and Cooktops) 0 07-25-2009 10:54 AM
Replaced all HV parts still have problem CJ14 Microwave Repair 0 01-16-2009 12:37 PM
Admiral Washer Parts in Canada? slarter Washer Repair 1 10-07-2008 04:25 PM
How do I determine what parts need to be replaced for heating Chief Dryer Repair 2 11-19-2007 10:40 PM
Wont start/start switch replaced awilliams197 Dryer Repair 1 09-18-2007 01:33 AM
