Discuss
Gas Dryer Drum Doesn't Turn After Pushing Button.
 in
Dryer Repair
Hi, I have had trouble with this dryer previously but for a non-related issue. I replaced the coils after coming
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer Drum Doesn't Turn After Pushing Button.
  #1 (permalink)
Old 01-31-2010, 12:41 PM
Junior Member
redeyedog is on a distinguished road
Default Gas Dryer Drum Doesn't Turn After Pushing Button.
Model Number: LGR3624EQ0   Brand: Whirlpool   Age: More than 10 years
I have had trouble with this dryer previously but for a non-related issue. I replaced the coils after coming here and it has worked great ever since.
Recently, I started noticing that it was taking longer for loads to dry but the heat seems to work fine. I checked the exhaust and it is not clogged. In the last few loads, I noticed that a squeak was developing while the drum was turning.
Then I noticed that it seemed like the dryer was taking longer to start. I push the button and the sound is heard of it starting by it doesn't start as quickly. Then, I began hearing louder squeaking noises.
I checked the drum and noticed that it was difficult to turn. Not always but seemed like on one side of the turn. Then, it finished a load and now, it will no longer start.
I press the button and hear the motor actuate but it doesn't turn the drum, just hums. I let go of the button and humming stops. I am assuming that I have a belt issue but I was hoping to get some feedback here because I am in no way, skilled at this. Also, I noticed that the drum does not seem to be "exactly" centered on the front. I can lift the drum slightly up and down. I believe there is a sleeve that the drum slides on there.
As always, I appreciate any help. Thanks..
Update: I did something I probably wasn't supposed to do but I wanted to see if the drum was turning at all when I pushed the start button. So, I opened the door and pushed the little switch that the door pushes on and then hit the start button.
The drum is definitely trying to spin but seems like it is dragging real hard. Turning the drum by hand is quite difficult but it does spin. I hope the extra information might help someone looking at this post.
Thanks again!
Update 2: OK. I removed all the clothing which were a bit wet still, and tried again to turn it on. It started and spun for about 15 seconds. Then I heard a click and it shut down. After that the only sound I could hear was the timer.
Update 3. Picture added of motor location. I didn't remember taking pictures last time when I replaced the coils but I'm hoping someone recognizes this setup and might point me to a manual or maybe provide some instructions on how to work on this thing.
The coils were relatively easy to replace once they were determined to be the problem but this thing looks like it has to be accessed from the front and as you can see, it sits all the way to the back.
If an other photos or information is needed, please let me know. I'm in the process of pulling the front end off again. Thanks!
Ads By Google
Related Models
Whirlpool LGR3624EQ0
Whirlpool LGR3624EQ1
Whirlpool LGR3624EQ2
Whirlpool LGR3624JQ0
Whirlpool LGR3624JQ1
Whirlpool LGR3624JQ3 29" Gas Dryer
Whirlpool LGR3624PQ0 29" Gas Dryer
Whirlpool LGR3624PQ1 29" Gas Dryer
Whirlpool LGR3634EW0
Whirlpool LGR3634EW1
Whirlpool LGR3634EW2
Whirlpool LGR3634EW3
Whirlpool LGR3634JW0
Whirlpool LGR3634JW1
Whirlpool LGR3634JW2
Admiral LGR3725ADC Range - S/c F/s Gas
Whirlpool LGR4434AN0
Whirlpool LGR4434AN1
Whirlpool LGR4434AQ0
Whirlpool LGR4434AQ1
Whirlpool LGR4434AW0
Whirlpool LGR4434AW1
Whirlpool LGR4436AN0
Whirlpool LGR4436AW0
Whirlpool LGR4600PQ0 29" Gas Dryer
Whirlpool LGR4600PQ1 29" Gas Dryer
Whirlpool LGR4624BN0
Whirlpool LGR4624BN1
Whirlpool LGR4624BN2
Whirlpool LGR4624BQ0
Whirlpool LGR4624BQ1
Whirlpool LGR4624BQ2
Whirlpool LGR4624BW0
Whirlpool LGR4624BW1
Whirlpool LGR4624BW2
Whirlpool LGR4624DQ0
Whirlpool LGR4624DQ1
Whirlpool LGR4624DZ0
Whirlpool LGR4624DZ1
Whirlpool LGR4634BQ0
Whirlpool LGR4634BQ1
Whirlpool LGR4634BQ2
Whirlpool LGR4634DQ0
Whirlpool LGR4634DQ1
Whirlpool LGR4634DZ0
Whirlpool LGR4634EQ0
Whirlpool LGR4634EQ1
Whirlpool LGR4634EQ2
Whirlpool LGR4634EQ3
Whirlpool LGR4634EW0
Whirlpool LGR4634EZ0
Whirlpool LGR4634EZ1
Whirlpool LGR4634EZ2
Whirlpool LGR4634EZ3
Whirlpool LGR4634JQ0
Whirlpool LGR4634JQ1
Whirlpool LGR4634JQ2
Whirlpool LGR4634JQ3 29" Gas Dryer
Whirlpool LGR4634JT0
Whirlpool LGR4634JT1
Whirlpool LGR4634JT2
Whirlpool LGR4634JT3 29" Gas Dryer
Whirlpool LGR4634JZ0
Whirlpool LGR4634JZ1
Whirlpool LGR4634PQ0 29" Gas Dryer
Whirlpool LGR4634PQ1 29" Gas Dryer
Whirlpool LGR4634PT0 29" Gas Dryer
Whirlpool LGR4634PT1 29" Gas Dryer
Whirlpool LGR5434AN0
Whirlpool LGR5434AW0
Whirlpool LGR5600HQ0
Whirlpool LGR5600HZ0
Whirlpool LGR5600JQ0
Whirlpool LGR5600JQ1
Whirlpool LGR5600JT0
Whirlpool LGR5600JT1
Whirlpool LGR5620KQ0
Whirlpool LGR5620KQ1
Whirlpool LGR5620KQ2 29"gas Dryer
Whirlpool LGR5624BN0
Whirlpool LGR5624BN1
Whirlpool LGR5624BN2
Whirlpool LGR5624BW0
Whirlpool LGR5624BW1
Whirlpool LGR5624BW2
Whirlpool LGR5624DQ0
Whirlpool LGR5624DQ1
Whirlpool LGR5624DW1
Whirlpool LGR5624DZ0
Whirlpool LGR5624DZ1
Whirlpool LGR5634AN0
Whirlpool LGR5634AQ0
Whirlpool LGR5634AQ1
Whirlpool LGR5634AQ2
Whirlpool LGR5634AW0
Whirlpool LGR5634DQ1
Whirlpool LGR5634EQ0
Whirlpool LGR5634EZ0
Whirlpool LGR5634LQ0
Whirlpool LGR5635LQ0 29"gas Dryer
Whirlpool LGR5635LQ1 29"gas Dryer
Whirlpool LGR5636DW0
Whirlpool LGR5636DW1
Whirlpool LGR5636EQ0
Whirlpool LGR5636EQ1
Whirlpool LGR5636EQ2
Whirlpool LGR5636EQ3
Whirlpool LGR5636EZ0
Whirlpool LGR5636EZ1
Whirlpool LGR5636EZ2
Whirlpool LGR5636EZ3
Whirlpool LGR5636JQ0
Whirlpool LGR5636JQ1
Whirlpool LGR5636JT0
Whirlpool LGR5636JT1
Whirlpool LGR5636KQ0
Whirlpool LGR5636KQ1
Whirlpool LGR5636KT0
Whirlpool LGR5636KT1
Whirlpool LGR5636LG0
  #2 (permalink)
Old 01-31-2010, 01:50 PM
Junior Member
Default
Please Delete..
  #3 (permalink)
Old 02-04-2010, 03:19 PM
Junior Member
Default
OK. The front is off again and everything looks just like the picture. First thing I checked is the belt and when the drum is centered, I would say the belt is a little loose.
Then I checked the front part of the motor you see in the picture. To check it, I first lifted the drum up so that there is no tension from the belt at the point of the front and tried to turn the armature using the motor shaft.
From the front I could barely get the armature to turn, but it did turn some. Then I checked the back of the armature where the fins are. I turned the fins in both directions with relatively easy force.
I don't have a manual but it looks like the front part of the armature is supported by some bearings. Would it be possible to replace those bearings? Or is it just as much work to replace the whole motor?
Appreciate anything at this point..
Update: OK. I pulled out the drum and do not see anything defective that sticks out. With the drum out, I cleaned up a bit and tested the motor. When the drum is out, the motor spins and hums.
The support wheels also spin freely. Everything seems to work when the drum is out.
HELP!!!
Update: I did a bit more inspecting and this is what I found. Both of the seals on the drum had a bit of lint stuck to them but I would call it minimal so I removed that with a fingernail.
I looked at the motor again because none of this is making sense to me. The armature spins pretty freely however:
1. When it is turned, it kind of sounds like it is turning on felt, instead of what I would normally expect it to sound like.
2. When I turn it counter-clockwise, there is no squeak. When I turn it clockwise, there is a squeak. However, turning in either direction offers the same resistance. It seems to turn pretty easy.
3. There is no play in the motor shaft while it remains mounted.
I know I could find out more if I remove the motor but I am concerned about removing the two clips which seem to be what holds it in place.
  #4 (permalink)
Old 02-06-2010, 02:40 PM
Junior Member
Lightbulb
With no other direction to go, I decided to remove the clips holding the motor in place hoping that it would pull out but it doesn't. I believe that is what the tag on the motor is referring to at this point to separate the motor shaft from the blower.
Unfortunately, the blower is located on the other side of the cabinet wall and to access it, you have to remove that lint trap housing. I didn't want to go there so since the motor shaft was spinning freely, I decided that the problem was a severe lint build up in that blower area. Maybe it worked itself loose.
I put everything back together and turned it on. It started right up and whole mess of lint and crap came flying out the exhaust. I figured this must have been happening for quite some time so I cleared the exhaust pipe leading to the outdoors. I straightened out a metal coat hanger and bent a "U" at one using a pair of pliers and reached inside the exhaist as far as I could while the dryer was running. There was a whole mess of lint and crap in there, too!
You would think my problem is solved at this point but I'm not so sure. A few minutes after starting, the dryer started making this dreaded squeaking noise coming from the back of the unit, most likely from that blower area. Then, it just went away. Hmmmm.
Anyway, the pics I included here show the clip which locks the front of the motor shaft in place. The back one is very similar except it is wider. The back one goes back on without any problem but the front one wasn't so easy. I ended up using a small pair of channel locks using that hole to pull the clip down to lock it in place. Worked like a charm!
Next test, dry clothes soon.
  #5 (permalink)
Old 04-16-2010, 04:00 PM
Junior Member
Default
OK. The motor is toast! I decided I need to replace it, however, separating the motor armature rod from the blower seems to be a trick. I have removed the front and rear clips holding the motor down to the base bracket. Then I removed the base bracket out of the way, too.
The blower fan sits on the other side of the housing, inside the blower enclosure which is held in place by 3 screws. However, to remove the screws holding the blower housing in place, you must first remove the blower fan to get to them. I can't remove the fan from the outside and the motor will not pull away from the inside.
Any ideas? What am I missing here?
  #6 (permalink)
Old 04-16-2010, 06:08 PM
Junior Member
Default
OK! It unscrews BUT "left hand thread" so it unscrews in the direction you would normally screw something on. So, you turn CLOCKWISE to loosen!!! DUH!!! I posted another pic. This one shows how to unscrew the blower fan from the motor armature rod. In the pic, the motor base plate has been removed already. I learned later that it wasn't necessary to remove the base plate.
NOTE: The blower fan is made of plastic and it is screwed onto a metal rod, so I sprayed some Break Away (GREAT STUFF) and waited about 30 minutes before trying.
I positioned a smaller adjustable wrench as close as possible against the back wall and made sure to tighten the wrench as snug as possible onto the fan. Since I am turning CLOCKWISE to loosen, I laid the end of the adjustable against the side of the cabinet to lock it in place.
I used a larger adjustable (the one that is turned CLOCKWISE) on the other end of the armature rod and gave a firm CLOCKWISE turn. It was either going to break or break free.
SUCCESS!! I don't know if it was the Break Away or not, but after it broke free, it screwed off CLOCKWISE easily the rest of the way.
Now to order a new motor from Appliance Pros and I'll try to follow up after installing the new motor. But if I do not make it back here, installation is in the reverse order. So, you would turn the motor armature rod COUNTER CLOCKWISE, in the same direction you would normally loosen something, to tighten the blower fan back on.
DO NOT OVER TIGHTEN because you are screwing a metal rod onto a plastic fan. The normal operation of the dryer will keep the fan tight.
That's why they use a "left hand thread."
  #7 (permalink)
Old 12-11-2010, 12:10 PM
Junior Member
Default
Just wanted to add some pics to finish this thread. The adjustable wrench along the back wall holds the fan from turning. Use the adjustable on the front of the motor shaft to turn CLOCKWISE to loosen the shaft. Spray a little breakaway a few minutes before and keep your fingers crossed that the fan doesn't break when you first break it loose. (I have read on this forum that it's normal for them to seize and usually break when trying to remove - metal on plastic).
Anyway, once the shaft is unscrewed from the fan, get the motor out of the way. Note that you will have to remove the duct on the back of the dryer to access to fan. However, if the motor comes off cleanly like mine did, you might be able to replace the motor without doing all of that. I removed it because I was concerned about a buildup of lint at the bottom of the fan housing.
Assemble in the reverse order and DO NOT OVER TIGHTEN the new motor shaft to the fan. Because the fan has a "left-hand" thread, the normal direction of spin keeps the shaft from unscrewing from the fan.
Hope this helps someone.. Everything continues to work nicely.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
on/off button buzzes and does not turn on dryer epatmi Dryer Repair 2 09-20-2011 03:23 PM
Dryer drum won't turn benabbott Dryer Repair 3 01-03-2010 07:33 AM
dryer willo not turn on when pushing the button maxxor Dryer Repair 3 01-15-2009 01:31 PM
Dryer drum won't turn marciabloem Dryer Repair 1 04-15-2008 05:16 PM
dryer drum won't turn coolrunning Dryer Repair 2 04-15-2008 11:58 AM
