Discuss
Frigidaire Affinity dryer error code E9E
 in
Dryer Repair
We just bought a new front load dryer from Lowe's about a month ago. We ran about 6 loads
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire Affinity dryer error code E9E
  #1 (permalink)
Old 04-21-2008, 11:33 AM
jpalazzi jpalazzi is offline
Junior Member
jpalazzi is on a distinguished road
Default Frigidaire Affinity dryer error code E9E
Model Number: AEQ6700FS   Brand: Frigidaire   Age: Less than 1 year
We just bought a new front load dryer from Lowe's about a month ago. We ran about 6 loads through it no problems. It started flashing a E9E error code. We called Frigidare and they said it was [FONT='Arial','sans-serif']voltage error in the control panel[/font]. They sent out a repair man. After he looked at it he said it was a motor problem and we should take it back.
We took the dryer back and after about 8 loads it began doing the same thing.
Its an electric dryer and at first I didnt have it grounded. So I thought that may be the problem. I grounded it and it still isnt working correctly. Now it wont even run for 5 seconds before flashing the code.
I checked the voltage and I get 116 volts between red and white, and around 119 between black and white. Between red and black I get around 230.
Any ideas before I take this one back and get a different model? We have had this series of washer and dryer before and had no problems.
Thanks for any advice.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Washer Error Code E10 11594 Washer Repair 2 04-16-2008 12:34 PM
dlf error code sjf961 Washer Repair 1 03-18-2008 07:57 PM
F3 Error Code Eva Oven Repair (including Ranges and Cooktops) 1 02-18-2008 12:27 PM
Frigidaire Oven F3 error code sbochen Oven Repair (including Ranges and Cooktops) 2 01-08-2008 09:38 AM
F22 error code on maytag bravos dryer heatherj Dryer Repair 0 10-27-2007 08:19 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
