| » GE dryer with no heat |
Model Number: DHSR333EV0WB Brand: GE Age: 5 - 10 years
I have checked for continuity on the thermal fuse and the heating element and both are good. The only suspect part that I have found is a thermostat located on the top of the heating element shroud that doesn't have continuity to just one post. Can anyone tell me if this could be the problem or do I need to keep looking?
There are three thermostats on or around the heating element. They all have to be closed to provide normal heating.
They are: the thermal fuse (#507 on the break down diagram), the hi limit thermostat (#505 on the break down diagram) and the cycling thermostat (# 506 on the break down diagram). Here are the break down diagrams for the GE dryer Model DHSR333EV0WB Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
