Discuss
Not tumbling
 in
Dryer Repair
My dryer is pumping air and heat into the clothes, but the cylinder is not rotating. I first opened the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Not tumbling
  #1 (permalink)
Old 04-20-2008, 03:42 PM
blofgren blofgren is offline
Junior Member
blofgren is on a distinguished road
Default Not tumbling
Model Number: LGR5634AWO   Brand: Whirlpool   Age: More than 10 years
My dryer is pumping air and heat into the clothes, but the cylinder is not rotating. I first opened the panel on the back, which gives access to the air in and out. Apparently I must open the front, but I'm not finding how. I'm also putting in a request directly to Whirlpool for the manual, but they are closed today. I guess I might need to replace a belt or maybe a motor.
Brent
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-20-2008, 07:15 PM
gearhead1218 gearhead1218 is offline
Member
gearhead1218 is on a distinguished road
Default
You need a belt.
If you click on your model# on your initial post you'll see a breakdown of your dryer.
You do need to remove the front.
You pull the lint filter, remove the two screws on the filter compartment, Then you can slide the top forward about a 1/4 inch to be able to lift the top. Undo the door switch, remove two 5/16 screws and you can remove the front to change the belt.
  #3 (permalink)
Old 04-21-2008, 07:59 AM
Junior Member
Default Thanks
Thanks, Gearhead. This site rocks, and I've ordered the belt from you. Mainly, it was smarter than the Whirlpool site at picking up that the last character in my model number is the number zero, rather than the letter O. I don't have immediate access to the dryer itself, but I hope that I will be able to open it up and replace the belt according to your instructions.
Brent
  #4 (permalink)
Old 04-21-2008, 01:48 PM
Member
Default
Glad I could help.
As an aside, I'm just a member here, not one of the people running the site.
  #5 (permalink)
Old 04-23-2008, 06:19 PM
Junior Member
Default Getting belt into idler
The idler pulley is supported on both sides, so it is a closed loop. The new belt is a closed loop, too. (As surmised, the old belt was completely broken.) How do I thread the belt through the idler? It seems like those rings that magicians use.
  #6 (permalink)
Old 04-23-2008, 06:47 PM
Member
Default
  #7 (permalink)
Old 09-24-2008, 04:51 PM
alexis123 alexis123 is offline
Junior Member
alexis123 is on a distinguished road
Default this is waht I repair
head1218;20263][/quote]
I did this alreeady do I need to tension the belt
  #8 (permalink)
Old 09-24-2008, 04:59 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
If The Belt Isn't Tight The Idler Pulley Arm May Be In The Wrong Slot.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stopped Tumbling Beth Dryer Repair 1 11-25-2007 07:43 AM
Friction while Tumbling Beth Dryer Repair 0 11-21-2007 06:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
