Discuss
Dead Panel on Maytag sg1000
 in
Dryer Repair
A few years ago we had a problem with our unit (it shut down in mid-wash cycle and the control
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dead Panel on Maytag sg1000
  #1 (permalink)
Old 01-30-2010, 11:34 AM
Junior Member
jefinch is on a distinguished road
Default Dead Panel on Maytag sg1000
Model Number: sg1000   Brand: Maytag   Age: More than 10 years
A few years ago we had a problem with our unit (it shut down in mid-wash cycle and the control panel was unresponsive). The short version is that I corresponded with an online tech who tentatively diagnosed the problem but recently my email inbox was deleted. I believe that he said the control panel needed to be replaced. We then had a repair tech look at it but the machine was working fine. So he confirmed the online diagnosis and concurred with the online advice that there were 2 parts that normally are replaced at the same time for this issue. Soon thereafter we moved to work-provided housing but have now returned and want to repair and use the machine. Can someone advise me on what that other part might be that should be replaced when the digital control panel quits working?
Ads By Google
Related Models
Maytag SG1000 Stacked Laundry - Gas
Maytag SG1000T Stacked Laundry - Gas
Hardwick SG1616A49R Range - F/s Std Gas
Hardwick SG1616W49R Range - F/s Std Gas
Hardwick SG1616Y49R Range - F/s Std Gas
Amana SG19SL Ref - SXS/I&W
Amana SG19SW Ref - SXS/I&W
Amana SG22MBG Ref - SXS/I&W
Amana SG22MBL Ref - SXS/I&W
Amana SG22MBW Ref - SXS/I&W
Amana SG521SBL Ref - SXS/I&W
Amana SG521SBW Ref - SXS/I&W
Amana SG521SW Ref - SXS/I&W
Maytag SG7800 Stacked Laundry - Gas
Hoover SG901---
Hoover SG903---
Hoover SG905---
Hoover SG907---
Hoover SG913---
Hoover SG915---
Hoover SG919---
Hoover SG921001
Hoover SG925
Hardwick SG9612A79RO Range - F/s Std Gas
Hardwick SG9612W79RO Range - F/s Std Gas
Hardwick SG9617A429R Range - F/s Std Gas
Hardwick SG9617W429R Range - F/s Std Gas
Maytag SG9900 Stacked Laundry - Gas
Thermador SGC304R
Thermador SGC304RB
Thermador SGC304RS
Whirlpool SGC355XW0
Whirlpool SGC355XW1
Whirlpool SGC355XX2
Whirlpool SGC355XX3
Thermador SGC365RB
Thermador SGC365RS
Thermador SGC365RW
Thermador SGC456RB
Thermador SGC456RB S\N 9803
Thermador SGC456RS
Thermador SGC456RS S\N 9803
Thermador SGC456RW
Thermador SGC456RW S\N 9803
Thermador SGCS304RB
Thermador SGCS304RS
Thermador SGCS304RW
Thermador SGCS365RB
Thermador SGCS365RS
Thermador SGCS365RW
Thermador SGCS456RB
Thermador SGCS456RB S\N 9803
Thermador SGCS456RS
Thermador SGCS456RS S\N 9803
Thermador SGCS456RW
Thermador SGCS456RW S\N 9803
Thermador SGCV36
Thermador SGCV3601
Thermador SGCV36G01
Thermador SGCV36G02
Amana SGD22TL Ref - SXS/I&W
Amana SGD22TW Ref - SXS/I&W
Amana SGD26VL Ref - SXS/I&W
Amana SGD26VW Ref - SXS/I&W
Amana SGD521SBL Ref - SXS/I&W
Amana SGD521SBW Ref - SXS/I&W
Amana SGD521SW Ref - SXS/I&W
Whirlpool SGDS800HQ0
Whirlpool SGDS800JQ0
Whirlpool SGDS800JQ1
Whirlpool SGDS800JQ2
Whirlpool SGDS800MQ0 29"gas Dryer
Whirlpool SGDS800MQ1 29"gas Dryer
Whirlpool SGDX600HQ0
Whirlpool SGDX600JQ0
Whirlpool SGDX600JQ1
Whirlpool SGDX600JQ2
Whirlpool SGDX600MQ0 29"gas Dryer
Whirlpool SGDX600MQ1 29"gas Dryer
Frigidaire SGER341AS0 Frigidaire/dryer
Frigidaire SGER341AS1 Frigidaire/electric Dryer
Frigidaire SGGR341AS0 Frigidaire/dryer
Frigidaire SGGR341AS1 Frigidaire/gas Dryer
Frigidaire SGGR341AS2 Frigidaire/gas Dryer
Thermador SGN30B
Thermador SGN30S
Thermador SGN30W
Thermador SGN36GB
Thermador SGN36GS
Thermador SGN36GW
Thermador SGNCV36GB
Thermador SGNCV36GS
Thermador SGNCV36GW
Whirlpool SGP335XW0
Whirlpool SGP335XW1
Whirlpool SGP335XX2
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR341AQ0 Dryer - W.west
White Westinghouse SGR341AQ1 Dryer - West/grupo Gomo
White Westinghouse SGR341AQ2 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ3 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ4 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ5 White Westinghouse/dryer
White Westinghouse SGR341AS0 Dryer - W.west
White Westinghouse SGR341AS1 Dryer - West/grupo Gomo
White Westinghouse SGR341AS2 White Westinghouse/gas Dryer
White Westinghouse SGR341AS3 White Westinghouse/gas Dryer
White Westinghouse SGR341AS4 White Westinghouse/gas Dryer
  #2 (permalink)
Old 01-31-2010, 07:02 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Quote:
Some guys, will tell you to replace the touch pad. I have replaced a ton of those controlboards when I worked for Maytag years ago, but only a few of the touch pads. The only reason, I replaced the touch pads is sometimes, every button did not work. Tom ******************************************** - Parts
  #3 (permalink)
Old 01-31-2010, 07:24 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for sg1000 models | AppliancePartsPros.com
Here is a manual which should help if you decide to do the work yourself
http://www.servicematters.com/maytag...s/16000416.pdf
Also gives some info on checking the boards.
__________________
  #4 (permalink)
Old 02-01-2010, 07:40 PM
Junior Member
Default
Quote:
At this point nothing works. There's no response from the touch panel or anything else. Is it the circuit board that I should be looking to replace instead?
  #5 (permalink)
Old 02-02-2010, 01:47 AM
Senior Expert
APP Volunteer
Default
In your original post you said the unit went down and then you had a tech come in and it was running.
Was it totally dead the first time?
What if anything did you do to get it running again?
Could be you have a loose/bad connection somewhere.
You may want to try the following cleaning.
As with any unit that is totally dead it is best to check the power at the receptacle first.
Then power in the machine just in case you have a bad power cord.
Also this unit has a transformer (Item 28 in Section 4) so I would check that it's output voltages are OK.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the other connectors on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
  #6 (permalink)
Old 02-02-2010, 04:40 AM
Senior Expert
APP Volunteer
Default
Yes the control board would most likely be the issue. The part # is 33001048. It is also still available. Tom ******************************************** - Parts
  #7 (permalink)
Old 02-02-2010, 04:49 PM
Junior Member
Default
Yes the first time it was totally dead as it is now. The odd thing was that we did nothing to get it going again. It just sat for a number of weeks until we decided to call the repair tech. When he started his diagnosis nothing was wrong and we used the machine for a while more before it stopped working again. I'm certain the receptacle is hot but the loose connection is a good thing to try. Thanks for the step by step instructions to give that a try.
  #8 (permalink)
Old 02-15-2010, 08:24 AM
Junior Member
Default
I tried the cleaning. First just the ribbon cable. Then I plugged both cords back in. When I plugged in the dryer cord I heard a faint humming sound, which actually had been present before unplugging for the cleaning. When I plugged in the washer cord the washing machine came on in the agitation cycle. There was still no response from the control panel. I then pulled the panel and circuit board and cleaned the contacts on the board with a pencil eraser and my thumbnail. I inspected the board and don't see any obvious bad spots. Put it all back together and the washer runs in agitation and there's no response from the control panel. Still sounding like a problem with the circuit board?
  #9 (permalink)
Old 02-16-2010, 04:47 AM
Senior Expert
APP Volunteer
Default
It sounds like it to me!! Tom ********************************************
  #10 (permalink)
Old 02-20-2010, 12:47 PM
Junior Member
Default
The new circuit board came yesterday and I installed it this afternoon. No change in the machine's actions: washer runs in agitation and there is no response from the control panel. I don't think this should matter but do not have the water turned on yet to the machine. What next? Replace the touch pad? I assume I can't return the circuit board if I determine that mine is OK as it looks like might be the case?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Diswasher control panel dead LarrySal Dishwasher Repair 0 11-12-2009 09:32 AM
Dead control panel caldwell.70 Dryer Repair 3 10-23-2009 06:01 AM
Control Panel is dead rileyd Oven Repair (including Ranges and Cooktops) 3 10-13-2009 05:10 PM
Maytag SG1000 (older unit) down! S.O.S. !!!! wavecowboy Dryer Repair 0 01-10-2009 06:17 PM
Dryer Control Panel Dead! Corel Dryer Repair 1 08-10-2007 08:47 PM
