Discuss
Dead Panel on Maytag sg1000
 in
Dryer Repair
Hi Jefinch, I had the same exact situation with my Maytag SG1000. I tried installing the least expensive part first,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dead Panel on Maytag sg1000
  #11 (permalink)
Old 07-16-2017, 08:07 AM
Junior Member
AntiPlannedObsolescence is on a distinguished road
Default
Hi Jefinch,
I tried installing the least expensive part first, the touch pad, and Voila! Instant functionality! One touch does it!
So, for future reference, if it takes a prolonged pushing of the touchpad buttons to get it to work, it more than likely is the touchpad, not the more expensive circuit board.
Also, inspection of the ribbon cable from the old touchpad showed that one or two of the flat ‘wires’ appeared to have leached / bled out. Perhaps that’s what caused a gradual build-up of resistance leading to the eventual failure.
I'm posting this in hope it can help other folks.
Lastly, that humming you mentioned is the transformer. It hums softly whenever the machine is plugged in. That's normal.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Diswasher control panel dead LarrySal Dishwasher Repair 0 11-12-2009 09:32 AM
Dead control panel caldwell.70 Dryer Repair 3 10-23-2009 06:01 AM
Control Panel is dead rileyd Oven Repair (including Ranges and Cooktops) 3 10-13-2009 05:10 PM
Maytag SG1000 (older unit) down! S.O.S. !!!! wavecowboy Dryer Repair 0 01-10-2009 06:17 PM
Dryer Control Panel Dead! Corel Dryer Repair 1 08-10-2007 08:47 PM
