18wheeler
#1 Posted : Saturday, January 30, 2010 9:16:47 AM(UTC)
18wheeler
Dryer Runs...no Heat...check Continuity And Found The Thermal Cut Off For Dryer Heating Element 352 Deg. With No Continuiity..can It Be That Simple...
#2 Posted : Saturday, January 30, 2010 2:52:10 PM(UTC)
[COLOR="Blue"]Thermal Cut Off For Dryer Heating Element 352 Deg. With No Continuiity..can It Be That Simple..[/COLOR]
Sort of
You have to find out what caused it to blow.
Usually when you replace this fuse you also replace the hi-limit thermostat (they come in a kit) as that should have regulated the temperature and prevented the fuse from blowing.
An exception would be the following:
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above measures OK then other possible causes are:
Dirty vent system.
Bad seals in the unit (drum seals etc.)
Dirty or loose blower wheel.
Lint filter clogged up with fabric softener residue.
Bad cycling thermostat
And probably some I have not thought of.
kayakcrzy
#3 Posted : Sunday, January 31, 2010 5:44:33 AM(UTC)
kayakcrzy
Yes!!!! applianceeducator.com/parts.htm
kayakcrzy
#4 Posted : Sunday, January 31, 2010 5:46:13 AM(UTC)
kayakcrzy
Yes!!!! Tom ApplianceEducator.com
Kenmore Series 80 Electric Dryer not heating (Dryer Repair)
by Steven7171 3/30/2014 5:07:52 PM(UTC)
Electric Dryer Not Heating (Dryer Repair)
by bselff 12/20/2011 12:58:18 PM(UTC)
Estate(Whirlpool) Electric Dryer not heating (Dryer Repair)
by JDB59 11/23/2011 2:05:23 PM(UTC)
by inneedofhelpplease 3/17/2011 4:03:02 PM(UTC)
Whirlpool Electric Dryer not heating (Dryer Repair)
by choover1119 3/13/2011 11:02:32 AM(UTC)
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 1/6/2011 6:58:54 PM(UTC)
Maytag electric dryer not heating up (Dryer Repair)
by jmlpa 12/7/2010 9:41:11 AM(UTC)
electric dryer not heating (Dryer Repair)
by notimetowait 10/1/2010 6:26:06 PM(UTC)
by hrose 5/19/2010 5:45:56 PM(UTC)
Electric dryer not heating (Dryer Repair)
by phut 1/21/2010 4:30:21 PM(UTC)
by glopez01 12/7/2009 12:41:37 PM(UTC)
Electric Dryer Not heating (Dryer Repair)
by Danske 11/23/2009 4:19:41 PM(UTC)
Electric Dryer Not Heating (Oven Repair (including Ranges and Cooktops))
by bkeiger 7/31/2009 12:27:48 PM(UTC)
electric Dryer not heating (Dryer Repair)
by RJ Trucks 7/28/2009 10:52:36 AM(UTC)
by Global Kiss 7/16/2009 10:33:02 AM(UTC)
