Discuss
Maytag dryer won't start- thermostat question?
 in
Dryer Repair
I have a Maytag dryer that was working and stopped during a cycle. I pulled off the front cover and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag dryer won't start- thermostat question?
  #1 (permalink)
Old 01-30-2010, 05:43 AM
Junior Member
Underdog is on a distinguished road
Default Maytag dryer won't start- thermostat question?
Model Number: pye2300ayw   Brand: Maytag   Age: 1 - 5 years
I have a Maytag dryer that was working and stopped during a cycle. I pulled off the front cover and found that lint and hair had almost completely stopped air flow. I cleaned the lint and hair away from the dryer and all parts. Checked continuity on the high temp shut off- it read almost 0 omhs. Checked the thermostat at the blower and it reads 0 omhs at the two main leads, but also has two smaller leads on the top and bottom...when I check those the it shows very little on the meter.
Am I checking the thermostat properly?
BTW...motor moves freely and the high temp cutoff reads 0 omhs.
Should I just replace the thermostat?
Ads By Google
Related Models
Maytag PYE2300AYW Dryer - Ele
Maytag PYE2300AZW Dryer - Ele
International PYE3200AGW Dryer - Ele
Maytag PYE3200AYW Dryer - Ele
Maytag PYE3200AZW Dryer - Ele
International PYE3300AGW Dryer - Ele
International PYE3300AKW Dryer - Ele
Maytag PYE3300AYW Dryer - Ele
Maytag PYE3300AZW Dryer - Ele
Maytag PYE3360AYW Dryer - Ele
Maytag PYE4500AYQ Dryer - Ele
Maytag PYE4500AYW Dryer - Ele
Maytag PYE4500AZW Dryer - Ele
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
  #2 (permalink)
Old 01-30-2010, 07:10 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG PYE2300AYW Dryer - Ele | AppliancePartsPros.com
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Then check the door switch. Mechanically first to make sure it is being closed.
Then with a meter to be sure it's contacts are closing.
Next would be the thermal fuse Item 5 in Section 5
Unplug the unit and check it with a meter, should be 0 ohms.
Be sure to unplug one side of it when checking it.
If it is blown you have to find out what caused it to go.
It could be just the clog you had.
You will see it comes with a hi-limit thermostat as this thermostat should have regulated the temperature so that the fuse did not blow. It did not so it is assumed that it is bad.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
Just so we do not get confused use please use the terminology on the wiring diagram: thermal fuse; Safety thermostat (actually the hi-limit) and thermostat (actually the cycling thermostat)
The thermostat has 4 connections 2 of them are the contacts they should read 0 ohms, the other two are the internal heater they should read approximately 29,000 ohms.
See below
No, it seems OK you may want to recheck it, see below.
__________________
  #3 (permalink)
Old 01-31-2010, 07:24 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
The part you need is a thermal fuse kit. The part # is LA1053. If you pop the top of the dryer, and make sure you have it unplugged. You will see the heater in the back on the top, lookto the right of the heater housing, and follow the 2 white wires, and you will see the thermal fuse connected to the 2 white wires. It will be the size of a dime, and round. The best wat to replace it is just take the thermostat bracket off of the element housing. Take the lonf 1/4 inch screw that holds the element in place out, and pull the element, and then get a screw driver and pop out thermal fuse housing.
Once that is all done and you have the new one. Let's repair the reason why it went. While you still have the top up, we need to take the front off. There will be a screw on the inside of the front left side, about 6 inches down, it will be a 1/4 head size screw. Remove it, and the one on the other side. Then lean the front towards you, and remove the door switch wires. Remember where they go, and remove the front. Look down on the front on the bottom, where the blower housing is, and pull out all the lint. Reach inside the vent housing and clean it out good. It is a great dryer, but the vent system stinks. Put it back together, and you have it!! Let me know how it goes. Tom www.********************************************/parts,htm
  #4 (permalink)
Old 02-01-2010, 11:53 AM
Junior Member
Default
Thanks Kayak... it is in fact the thermal fuse. Ditto...the exhaust system bites. How often should I take the dryer apart to clean it.
Thanks for all the help guys!
  #5 (permalink)
Old 02-01-2010, 11:57 AM
Senior Expert
APP Volunteer
Default
once every 6 months. Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dryer won't start - all switches, fuse, thermostat OK grosvenor3 Dryer Repair 7 12-10-2009 05:49 PM
Free Thermostat fuse for Maytag gas dryer JohnGoubeaux Dryer Repair 0 11-05-2009 12:03 PM
Free Thermostat fuse for Maytag gas dryer JohnGoubeaux Dryer Repair 0 11-05-2009 11:58 AM
Dryer still won't start, have replaced thermal fuse and thermostat-fix JRHeck Dryer Repair 2 06-17-2009 08:52 AM
Maytag Dryer Repair Question deeboi74 Dryer Repair 2 07-14-2008 07:24 PM
