Discuss
Dryer stops in middle of cycle
 in
Dryer Repair
Hope someone can help. I have a Kenmore 90 Series dryer that is working great except that it stops in
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer stops in middle of cycle
  #1 (permalink)
Old 04-19-2008, 02:31 PM
Junior Member
JohnG is on a distinguished road
Default Dryer stops in middle of cycle
Model Number: 110.78932790   Brand: Kenmore   Age: 5 - 10 years
Hope someone can help. I have a Kenmore 90 Series dryer that is working great except that it stops in the middle of the cycle. Doesn't seem to matter if it's the timer or the auto dry. I have already replaced the thermistor, thought it was allowing the temp range to be too high. it has stopped during air dry or any of the fabric settings. I monitored the voltage on the motor relay, BU (it goes through the timer) and it looked steady. it seems the relay is clicking off at just about the time the dryer turns off. No buzzer turns on, so i'm guessing that the timer seems good. I think i'm down to the even heat card, but would like suggestions to check anything else before I go buying that.
John
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 04-20-2008, 08:12 PM
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Before replacing any other parts try this.
Gain access to the motor,
If there is any lint at all on it then make sure
to give it a good cleaning. Make sure both
the front and rear sides of the motor are clean.
Then give it a tests run.
  #3 (permalink)
Old 04-21-2008, 04:10 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Stick 115 volts to motor pins 4&5 and let it run and check if it turns itself off, if ok you probably have a bad pc board.
__________________
  #4 (permalink)
Old 04-22-2008, 10:59 PM
Junior Member
Default
glen65 & richappy -- Thank you for the information an suggestions. I did open up the dryer and cleaned out the motor, boy was it dusty and dirty. I didn't have any test jumpers to test the motor though. I looked several minutes at the diagrams and considered jumpering around the relays and pc board to turn the motor on, but decided not to. The correct way was to test the motor isolated from the dryer circuits and since I didn't have a safe way to do that right then decided not to test the motor. Packed everything back up and did a test run (cotton temp, timed dry for 60 minutes). It didn't stop. I'll run it some more before I consider it a success, but this is a positive step. Thanks again!
-John
  #5 (permalink)
Old 04-26-2008, 04:33 PM
Junior Member
Default
glen65 & richappy -- Well it's been a week and the dryer continued to work. No more stopping. Thank you very much for your suggestions.
-John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dryer stops in middle of drying cycle tekatoo Dryer Repair 1 01-24-2010 08:33 AM
Washer stops in middle of cycle shuts off hellmanjeffrey@yahoo.com Refrigerator & Freezer Repair 4 01-10-2010 10:19 AM
Dryer stops in middle of cooldown cycle alan93 Dryer Repair 2 01-19-2009 07:01 AM
dryer stops in the middle of a load tmatkins Dryer Repair 1 06-11-2008 08:28 PM
washer stops in the middle of wash cycle cnic4 Washer Repair 1 10-20-2007 04:21 AM
