Discuss
E1 Code
 in
Dryer Repair
Started getting nuisance "E-1" codes on my Whirlpool Duet drier. The service paperwork (in the machine) indicates
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » E1 Code
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-19-2008, 10:50 AM
JSiemens JSiemens is offline
Junior Member
JSiemens is on a distinguished road
Default E1 Code
Model Number: GGW 9200   Brand: Whirlpool   Age: 5 - 10 years
Started getting nuisance "E-1" codes on my Whirlpool Duet drier. The service paperwork (in the machine) indicates a bad door switch or replace the electronic control. Anyone had to deal with this? If I need a control, does anyone know where I can purchase?
Thanks very much!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-19-2008, 06:58 PM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Re-check the model number from the model and serial
tag on the machine. The one you have listed is incomplete.
  #3 (permalink)
Old 04-20-2008, 05:31 AM
Junior Member
Default
Thanks for the response. The complete model number is GGW9200LWO. I was going to remove the termistor to have a look and check its resistance (guess I could do that while it installed) though. Anyway in order to get to it I removed the filter housing. I found it over 50% blocked with lint! I now have a note to do that annually. I cleaned it up but the problem actually still exists. The machine works fine for a while but continues to develop the "E1" diagnostic on the readout. Once reset it can be restarted. I am assuming bad thermistor or bad board. Should I attempt to measure discharge air temperatures at different settings to see if temps are correct?
  #4 (permalink)
Old 04-20-2008, 09:09 AM
Senior Expert
APP Volunteer
Default
You can check the connections at the control, but
E-1 is almost always a bad thermistor, (an open one).
I have seen cases where a fault at the boards input
would cause a false E-1 error, but its rare. So I
would recommend replacing the thermistor.
  #5 (permalink)
Old 04-20-2008, 03:18 PM
Junior Member
Default
Thanks so much...........I am 62 years old and have NEVER had a repairman in my house (but that is getting more difficult each year!)....I appreciate your eagerness to assist. I will get the part on order this evening. Lastly, I found a complete .pdf download for my Duet washer manual.....does anyone know where I might link to one for the drier?
Thanks again...........later yesterday the A/C died in my car.....my troubles usually occur in "threes" so wish me luck!!!
  #6 (permalink)
Old 04-20-2008, 06:04 PM
Senior Expert
APP Volunteer
Default
Right here..
  #7 (permalink)
Old 04-25-2008, 05:36 AM
Junior Member
Default
On Time And Under Budget!!
One more thank you; my dryer is now back in service. The problem was the termistor, exactly as you called it. It was a bit baffling at the beginning because the dryer still functioned; it would only quit after a half hours use. Tricky devices, those termistors! Lesson learned.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HF code jenn Washer Repair 0 02-17-2008 09:21 AM
code ld dllee021 Washer Repair 1 01-14-2008 07:43 PM
F08 code grivk Oven Repair (including Ranges and Cooktops) 0 11-23-2007 09:34 AM
f3 code....still beermebeerme Oven Repair (including Ranges and Cooktops) 1 11-05-2007 04:30 AM
F3 code...again beermebeerme Oven Repair (including Ranges and Cooktops) 1 10-16-2007 09:21 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
